Just finished recapping a CA-810 and put in 4 new lamps from Dgwojo, they are marked 14v/80ma/4.12mm. They all lit up, so I buttoned her up and thought I was good to go. But after I fired her up it looked like the lamps weren't working.
But the metal case over the lamps was warm, so I pulled it apart and the lamps were working. I put it back together and sure enough there was a little light there, but very dim. Pulled it out again and removed the blue filter and after reassembling, with that change the meters were acceptably bright.
The lamp assembly seems simple enough to put back together, but am I the dim bulb here? Or could it be the lamps just aren't bright enough to put enough light through the blue filter? I haven't seen a CA-810 with working lamps so I have nothing to gauge it against, but I'm sure they must be brighter than what I have.
