I'm attaching a picture of the serial number to see if they actually used to be mine.
Sorry for the lack of replies!!
Yes - I got them from Frank - they are yours..
Nice to meet the original owner!
Only the bass worked on one panel when I got them..
Sorry its been a whirlwind few days.. but after about 12 hours total (4 hours with acetone stripping wire and cleaning mylar, 8 hours rewiring and tweaking).. I now have two fully working MGII's.
My back is about shot from bending over them all day yesterday. I made some mistakes in the process - mainly from my back getting worse over the course of the day and me not concentrating as well... but I got it all sorted out.
I can tell you this - the wiring on the bass panels isnt as crucial as you would think. The first panel has pretty clean wiring runs.. but the second one I had a big problem with the adhesive (3M 77) drying out and not holding the wires down. I used about 100 (literally) washers to hold down the wires as the 30nf dried... I then went back and hit a couple of ugly spots again with some large fender washers and more glue... now its all good - but its ugly as hell.
I also screwed up and didnt realize that magenepan had sent me two spools of the bass panel wire - once again - not thinking clearly with my back killing me... and I ran out of wire half way through. So I made a junction block and soldered in some new wire... and finished.
The runs on the second bass panel are nasty.. wavy but mostly in the magnet gaps.
Tweeter runs are like factory - perfect... the tweeter wire is a dream to run, and you can do it in about 15 minutes.
I tested resistance on each wiring section and all match within about 1/3-1/2 ohm. Panels are about 1/2 ohm apart total... I think one is around 6.1 and the other around 6.5 ohms total.
Play testing was perfect - great response and no differences between panels that I can tell. I did some quick RTA on them with my DEQ2496 and they look to be running from around 40hz-14.5khz or so... It was nearly midnight so I couldnt push the pink noise up very loud.. but will retest tonight.
Not overly concerned if the high end is a bit rolled off as my hearing doent get up past about 14k anyways...
Tonight the socks go back on.
I'll look into the base plate as you mentioned.. thanks for the heads up! Hopefully I can post some pics tonight!
