QUOTE by Mark The FIXER;
+ and - 80mA markings on the big schematic in the manual infer 40mA per channel, but the manual says 50mV at the test point.
edit- SAME error as that's in the SX-1010 manual - see this
thread
Since there are four outputs PER CHANNEL, each transistor pair is 20 mA which is reasonable.
The voltage difference tho, ISN'T ADDITIVE (equipotential rule)- which is where they made their error.
THUS in my somewhat informed opinion it is reasonable to set to 20mV at the test points, which then multiplied by 4 sets of transistors results in the 80mA schematic notation.
If 50mA doesn't heat up badly, use it. The heat really comes on at higher amplifier power outputs and the slightly higher idle current will NOT make a significant difference in THOSE temperatures.
