Pioneer QX-9900 Recap
gorfmonger
Hello Everyone,
I am working on a QX-9900 and was wondering if anybody that has recapped one, has a complete list of all the caps. I have seen complete cap lists before but I am unable to find them now. Any help and tips would be great. Thanks. Todd
Mark
Thank for the info. I am new to this so please excuse any dumb questions.
If the receiver is working properly should I just replace the caps or go ahead and replace the transistors also?
What type of caps should I use when i begin the process?
Yes, capacitors and selected transistors. The qx-9900 is full of transistors that we view suspiciously now, and since you are in there for the caps, might as well get the known troublemakers out. Probably will sound better too, as we have seen examples of deterioration without failure.
Nichicon UPW, UHE and special UKL
Panasonic FC, FM
You will be TOLD which caps and transistors to get, we just need you to start the process and transcribe the BOM from the service manual to online. That's the time consuming part. Once THAT's done, then we start really cooking.
With the raw lists we will come up with replacement parts numbers, for both the capacitors and the transistors.
List the electrolytic capacitors (including the "cea", "cssa", "ceanl", "csza" descriptors) and transistors and diodes for the unit. By board and part number.
Just the electrolytic capacitors, the mylar, ceramic or whatever other caps don't need replacement.
protection unit 1 awm-028
awm-028 C3 470 6v cea 471p 6
awm-028 C5 4.7 25v cea 4r7p 25
awm-028 q1 2sc857k-a (don't need the "or")
awm-028 q3 2sc945-q
awm-028 d1 1s2471
and so forth for the entire unit.
I did one about 5 years ago, but don't have the list anymore. I had to make up my own.
Stock up on KSA-992's to replace all of the 2sa725 and 726's. I remember this being flooded with them. And get some KSC3503's to replace the 2sc1451's on the amp boards(2 amp boards). I didn't do the QUAD BOARDS. The 2 channels boards, amps, and power supply were enough on this one. Also there are a 747 Cargo Jet load of 2sc458's in it. They breakdown C-E and cause all kinds of problems. Replace with KSC-1845's.
Definately go over ALL of the POTS, Switches, on the front and back panels with DeOxit, MORE THAN ONCE! Do not scrimp on just cleaning the Bias and offset pots(VR's) on the amp boards. REPLACE THEM.
The Left and Right amp boards are Mirrored. You can count the caps and transistors on one then double the number.
Best way to approach it is one board at a time. Start with the POWER SUPPLY. Once the Output voltages are correct and inline, most everything will fall into place voltage wise, provided the rest is ol right now. Once you get the POWER SUPPLY done, then start at the inputs, and work your way from the input's to the output's one board at a time. IIRC a few are stacked and the one's you need to get to are on the bottom of the stack.
UNDO Wire ties, and retaining strings. DO NOT unwrap the wires from the pins!!! NEVER! If you need to remove, last resort is to de-solder the complete pin from the board. I never had to remove a pin or undo a wire. There is enough slack once you get the wire ties undone.
Get the COMPLETE Service manual (about 80 pages). Manual here Also get the addendum and compare serial #'s to see if it applies to yours.
Thanks to everyone for the valuable information. Now I know where to start and will transcribe the list once I get it completed. Thanks again. Todd
Todd; Post up the list by board # and part # (R1-C2, etc.) along with the type (cssa, cea, etc) and your proposed replacement BEFORE purchasing. This way we can vet it for you and make sure you have most current and correct parts on the list.
Read the PIONEER TUNING FORK GUIDES (There's a sticky thread at the top of the forum that has a lot of info that is directly pertinent to this.) Why certain types, and what each does, etc. And why one type is better than another. Any tantalums you find, replace with a stacked film type (Don't worry about the ECQ-V going out of production, there will be a replacement for it 30 years down the road if needed.).
Same goes for the Transistors. List them and their replacements.
Get enough ksc1845's and ksa992's to be able to make up matching pairs of them. IIRC, There are a couple spots where you'll need to match them for gain. 10 more than the number in the unit should be plenty. you'll surpass the price cut minimums and save even more.
Larry
Hello everybody,
I think I got the list done with all the electrolytic caps, transistors, and diodes. All the values are listed in uf unless otherwise stated. One problem I had is on page 37 of the manual, there is the fm front end (W11-045) that does not have a list of components. Does anyone have any suggestions on what I should do to find this information? Thanks for your help. Todd
FM/AM Unit AWE-015
AWE-015 C2, 38, 61 0.47 50V CEA R47P 50
AWE-015 C23, 29, 54 4.7 25V CEA 4R7P 25
AWE-015 C27, 58, 30 1 50V CEA 010P 50
AWE-015 C33, 65 100 16V CEA 101P 16
AWE-015 C36, 45 10 16V CEA 100P 16
AWE-015 C53 0.47 25V CSSA R47X 25
AWE-015 C55, 57 3.3 16V CSSA 3R3M 16
AWE-015 C66, 67 2.2 16V CSSA 2R2M 16
AWE-015 C73 47 16V CEA 470P 16
AWE-015 Q1, 2, 15 2SC738-D
AWE-015 Q3 TA7060P-GR
AWE-015 Q4, 13 2SC738-P
AWE-015 Q5, 6 TA7060P-BL
AWE-015 Q7, 8, 9, 10, 11, 14, 18, 20 2SC711-F
AWE-015 Q12 2SC382
AWE-015 Q16 2SK30-A
AWE-015 Q17 2SC870-F
AWE-015 Q19 2SC968-Y
AWE-015 Q21 M5109P
AWE-015 D2, 4, 5, 6, 7, 11, 1S188FM-1
12, 13, 14, 15
AWE-015 D3, 8, 9, 10 1S2076
HEAD AMP UNIT W21-002
W21-002 C1, 2 22 10V CEA 220P 10
W21-002 C3, 4 4.7 16V CEA 4R7P 16
W21-002 C5,6 10 25V CEA 100P 25
W21-002 C15 220 25V CEA 221P 25
W21-002 Q1, 2, 3, 4, 5, 6 2SC458LG-B
MIC AMP UNIT W21-003
W21-003 C1, 2, 11, 12 10 10V CEA 100P 10
W21-003 C7, 8 0.47 25V CSSA R47M 25
W21-003 C15, 16 100 35V CEA 101P 35
W21-003 Q1, 2, 3, 4 2SC1344
CONTROL AMP UNIT AWG-013
AWG-013 C3, 4, 21, 22 47 50V CEA 470P 50
AWG-013 C9, 10, 19, 20 100 6V CEA 101P 6
AWG-013 C13, 14 4.7 25V CEA 4R7P 25
AWG-013 C15, 16 10 25V CEA 100P 25
AWG-013 C23, 24 2.2 25V CSSA 2R2X 25
AWG-013 Q1, 2 2SK30A-GR
AWG-013 Q3, 4 2SA725-G
AWG-013 Q5, 6 2SC1312-G
MAIN AMP UNIT AWH-015
AWH-015 C1, 2, 23, 24 0.47 25V CSSA R47X 25
AWH-015 C7, 8 220 10V CEA 221P 10
AWH-015 C11, 12 100 50V CEA 101P 50
AWH-015 C19, 20 22 6V CEA 220P 6
AWH-015 C21 220 50V CEA 221P 50
AWH-015 Q1, 2, 3, 4 2SA726-GW
AWH-015 Q5, 6 2SC1124-2
AWH-015 Q7, 8 2SC1157-D
AWH-015 Q9, 10 2SA647-D
AWH-015 Q11, 12 2SC140Z-R
AWH-015 Q13, 14 2SA744-R
AWH-015 D1, 2 WZ-130
AWH-015 D3, 4 STV-4
AWH-015 D5, 6, 7 1S2473
PROTECTION UNIT 1 AWM-028
AWM-028 C3, 4 470 6V CEA 471P 6
AWM-028 C5 4.7 25V CEA 4R7P 25
AWM-028 C6 100 16V CEA 101P 16
AWM-028 Q1, 2 2SC857K-A
AWM-028 Q3, 4, 6 2SC945Q
AWM-028 Q5 2SA733Q
AWM-028 Q7 2SC1384-R
AWM-028 D1, 2, 3, 4, 5 1S2472
AWM-028 D6, 7, 8 1S2473
PROTECTION UNIT 2 AWM-029
AWM-029 Q1, 2 2SC857K-A
AWM-029 D1, 2, 3, 4 1S2472
DECODER UNIT AWM-031
AWM-031 C1,2 0.33 25V CSSA R33M 25
AWM-031 C15 220 35V CEA 221P 35
AWM-031 C16 1 25V CEA 010M 25
AWM-031 C17, 18, 19 1 25V CSSA 010M 25
AWM-031 C26, 27, 28
29, 30, 31 2.2 25V CSSA 2R2M 25
AWM-031 C32, 33, 34
35, 36, 37 2.2 25V CEA 2R2M 25NP
AWM-031 C38 100 35V CEA 101P 35
AWM-031 Q1, 3, 4, 15, 16, 19, 20 2SC1312-F
AWM-031 Q2, 5, 6, 17, 18 2SA725-F
AWM-031 Q7, 8, 9, 10, 11, 12, 13, 14 2SC1312-G
LOGIC UNIT AWM-032
AWM-032 C1,2 0.68 25V CSSA R68M 25
AWM-032 C5, 6 0.1 25V CSSA OR1M 25
AWM-032 C9,10,11,12 3.3 50V CEA 3R3P 50
AWM-032 C17 0.47 25V CSSA R47M 25
AWM-032 C18 10 16V CEA 100P 16
AWM-032 C19 47 50V CEA 470P 50
AWM-032 Q1, 2, 3, 4, 5, 6 2SC1312-G
AWM-032 Q7, 8 2SK30A-GR
AWM-032 D1, 2, 3, 4 1S188FM-1
AWM-032 D5, 6 1S2473
REVERB AMP UNIT AWM-036
AWM-036 C1, 2, 11, 12 0.1 25V CEA 0R1P 25
AWM-036 C5, 6, 16, 26 10 25V CEA 100P25
AWM-036 C13, 14, 31 4.7 25V CSSA 4R7M 25
AWM-036 C17, 19 33 50V CEA 330P 50
AWM-036 Q1, 2, 3, 7, 8, 9, 10 2SC1312F
AWM-036 Q4, 5 2SC1318R
AWM-036 Q6 2SA720R
POWER SUPPLY AWR-024
AWR-024 C11 1000 50V CEB102P 50
AWR-024 C12 1000 10V CEA102P 10
AWR-024 C13 220 50V CEA221P 50
AWR-024 C14, 16, 17 220 35V CEA221P 35
AWR-024 C15 100 16V CEA101P 16
AWR-024 Q1, 2 2SD313-E
AWR-024 Q3 2SC945-Q
AWR-024 D1, 2, 3, 4, 5, 6, 7, 8 SR3AM-4
AWR-024 D9, 10, 11 SIB01-01
AWR-024 D12 WZ130
MINI SWITCH UNIT AWS-025
AWS-025 D1, 2 1S188FM-1
SPEAKER SWITCH UNIT AWS-027
AWS-027 D1, 2 1S188FM-1
SPEAKER SWITCH UNIT A AWS-041
AWS-041 D1, 2 1S188FM-1
SPEAKER SWITCH UNIT B AWS-042
AWS-042 D1, 2 1S188FM-1
MISC PARTS
C3, 4, 5, 6 4700 50V ACH-16-A
Boards I NEVER mess with are TUNER Boards. Too many things to go wrong and you end up without a tuner. If the tuner is working now without problems, Make up a list of what you can with the info on the schematic and the actual board itself. Then don't do anything unless MARK THE FIXER says ok for specific parts on the FRONT END (w11-045), or the FM/AM Unit(AWE-015).
The reason for this is changing out parts on the tuner boards can change the alignment of the tuner and you loose part or all of the band(s). And getting it back in alignment takes specialized equipment, tools, and knowledg/practice/experience that most techs' don't have.
Hello Everyone,
Did anybody have a chance to look over the parts list. Just wondering if I need to list anything else?
Thanks
Todd
It looked a bit sparse, until I realized that it was multiple components per line, then I struggled a bit separating parts numbers (W21-003 C1, 2, 11, 12 10 10V CEA 100P 10) from capacitance..., referencing back to the manual.
W21-003 C1, C2, C11, C12 10 10V CEA 100P 10
You see, I normally inhale it into a spreadsheet and run it through some semi-automated processes and that format will cost me quite a bit of time adjusting before it can be inhaled, so the time to do that has to be found first.
THIS would be the most efficient for my "process":
(and what I will have to do to each and every line)
W21-003 C1 10 10V CEA 100P 10
W21-003 C2 10 10V CEA 100P 10
W21-003 C11 10 10V CEA 100P 10
W21-003 C12 10 10V CEA 100P 10
and I do have multiple reasons why I eventually landed on that seemingly inefficient format (usually it boils down to "exceptions")
The tuner "front end" and a lot of the rest of the tuner are left alone, to avoid disturbing the tuner's "alignment".
Mark,
I will go over the list and separate the parts that way it will be easier for you to digest. I should have it done tonight.
Thanks
Todd
Mark,
Here is the new list. Hopefully this will work better for you. Thanks. Todd
FM/AM UNIT AWE-015
AWE-015 C2 0.47 50V CEA R47P 50
AWE-015 C38 0.47 50V CEA R47P 50
AWE-015 C61 0.47 50V CEA R47P 50
AWE-015 C23 4.7 25V CEA 4R7P 25
AWE-015 C29 4.7 25V CEA 4R7P 25
AWE-015 C54 4.7 25V CEA 4R7P 25
AWE-015 C27 1 50V CEA 010P 50
AWE-015 C58 1 50V CEA 010P 50
AWE-015 C30 1 50V CEA 010P 50
AWE-015 C33 100 16V CEA 101P 16
AWE-015 C65 100 16V CEA 101P 16
AWE-015 C36 10 16V CEA 100P 16
AWE-015 C45 10 16V CEA 100P 16
AWE-015 C55 3.3 16V CSSA 3R3M 16
AWE-015 C57 3.3 16V CSSA 3R3M 16
AWE-015 C66 2.2 16V CSSA 2R2M 16
AWE-015 C67 2.2 16V CSSA 2R2M 16
AWE-015 Q1 2SC738-D
AWE-015 Q2 2SC738-D
AWE-015 Q15 2SC738-D
AWE-015 Q4 2SC738-P
AWE-015 Q13 2SC738-P
AWE-015 Q5 TA7060P-BL
AWE-015 Q6 TA7060P-BL
AWE-015 Q7 2SC711-F
AWE-015 Q8 2SC711-F
AWE-015 Q9 2SC711-F
AWE-015 Q10 2SC711-F
AWE-015 Q11 2SC711-F
AWE-015 Q14 2SC711-F
AWE-015 Q18 2SC711-F
AWE-015 Q20 2SC711-F
AWE-015 Q12 2SC382
AWE-015 Q16 2SK30-A
AWE-015 Q21 M5109P
AWE-015 D2 1S188FM-1
AWE-015 D4 1S188FM-1
AWE-015 D5 1S188FM-1
AWE-015 D6 1S188FM-1
AWE-015 D7 1S188FM-1
AWE-015 D11 1S188FM-1
AWE-015 D12 1S188FM-1
AWE-015 D13 1S188FM-1
AWE-015 D14 1S188FM-1
AWE-015 D15 1S188FM-1
AWE-015 D3 1S2076
AWE-015 D8 1S2076
AWE-015 D9 1S2076
AWE-015 D10 1S2076
W21-002 C1 22 10V CEA 220P 10
W21-002 C2 22 10V CEA 220P 10
W21-002 C3 4.7 16V CEA 4R7P 16
W21-002 C4 4.7 16V CEA 4R7P 16
W21-002 C5 10 25V CEA 100P 25
W21-002 C6 10 25V CEA 100P 25
W21-002 Q1 2SC458LG-B
W21-002 Q2 2SC458LG-B
W21-002 Q3 2SC458LG-B
W21-002 Q4 2SC458LG-B
W21-002 Q5 2SC458LG-B
W21-002 Q6 2SC458LG-B
W21-003 C7 0.47 25V CSSA R47M 25
W21-003 C8 0.47 25V CSSA R47M 25
W21-003 C15 100 35V CEA 101P 35
W21-003 C16 100 35V CEA 101P 35
W21-003 Q1 2SC1344
W21-003 Q2 2SC1344
W21-003 Q3 2SC1344
W21-003 Q4 2SC1344
AWG-013 C3 47 50V CEA 470P 50
AWG-013 C4 47 50V CEA 470P 50
AWG-013 C21 47 50V CEA 470P 50
AWG-013 C22 47 50V CEA 470P 50
AWG-013 C9 100 6V CEA 101P 6
AWG-013 C10 100 6V CEA 101P 6
AWG-013 C19 100 6V CEA 101P 6
AWG-013 C20 100 6V CEA 101P 6
AWG-013 C13 4.7 25V CEA 4R7P 25
AWG-013 C14 4.7 25V CEA 4R7P 25
AWG-013 C15 10 25V CEA 100P 25
AWG-013 C16 10 25V CEA 100P 25
AWG-013 C23 2.2 25V CSSA 2R2X 25
AWG-013 C24 2.2 25V CSSA 2R2X 25
AWG-013 Q1 2SK30A-GR
AWG-013 Q2 2SK30A-GR
AWG-013 Q3 2SA725-G
AWG-013 Q4 2SA725-G
AWG-013 Q5 2SC1312-G
AWG-013 Q6 2SC1312-G
AWH-015 C1 0.47 25V CSSA R47X 25
AWH-015 C2 0.47 25V CSSA R47X 25
AWH-015 C23 0.47 25V CSSA R47X 25
AWH-015 C24 0.47 25V CSSA R47X 25
AWH-015 C7 220 10V CEA 221P 10
AWH-015 C8 220 10V CEA 221P 10
AWH-015 C11 100 50V CEA 101P 50
AWH-015 C12 100 50V CEA 101P 50
AWH-015 C19 22 6V CEA 220P 6
AWH-015 C20 22 6V CEA 220P 6
AWH-015 Q1 2SA726-GW
AWH-015 Q2 2SA726-GW
AWH-015 Q3 2SA726-GW
AWH-015 Q4 2SA726-GW
AWH-015 Q5 2SC1124-2
AWH-015 Q6 2SC1124-2
AWH-015 Q7 2SC1157-D
AWH-015 Q8 2SC1157-D
AWH-015 Q9 2SA647-D
AWH-015 Q10 2SA647-D
AWH-015 Q11 2SC1402-R
AWH-015 Q12 2SC1402-R
AWH-015 Q13 2SA744-R
AWH-015 Q14 2SA744-R
AWH-015 D1 WZ-130
AWH-015 D2 WZ-130
AWH-015 D3 STV-4
AWH-015 D4 STV-4
AWH-015 D5 1S2473
AWH-015 D6 1S2473
AWH-015 D7 1S2473
AWM-028 C3 470 6V CEA 471P 6
AWM-028 C4 470 6V CEA 471P 6
AWM-028 Q1 2SC857K-A
AWM-028 Q2 2SC857K-A
AWM-028 Q3 2SC945Q
AWM-028 Q4 2SC945Q
AWM-028 Q6 2SC945Q
AWM-028 Q5 2SA733Q
AWM-028 D1 1S2472
AWM-028 D2 1S2472
AWM-028 D3 1S2472
AWM-028 D4 1S2472
AWM-028 D5 1S2472
AWM-028 D6 1S2473
AWM-028 D7 1S2473
AWM-028 D8 1S2473
AWM-029 Q1 2SC857K-A
AWM-029 Q2 2SC857K-A
AWM-029 D1 1S2472
AWM-029 D2 1S2472
AWM-029 D3 1S2472
AWM-029 D4 1S2472
AWM-031 C1 0.33 25V CSSA R33M 25
AWM-031 C2 0.33 25V CSSA R33M 25
AWM-031 C17 1 25V CSSA 010M 25
AWM-031 C18 1 25V CSSA 010M 25
AWM-031 C19 1 25V CSSA 010M 25
AWM-031 C26 2.2 25V CSSA 2R2M 25
AWM-031 C27 2.2 25V CSSA 2R2M 25
AWM-031 C28 2.2 25V CSSA 2R2M 25
AWM-031 C29 2.2 25V CSSA 2R2M 25
AWM-031 C30 2.2 25V CSSA 2R2M 25
AWM-031 C31 2.2 25V CSSA 2R2M 25
AWM-031 C32 2.2 25V CEA 2R2M 25NP
AWM-031 C33 2.2 25V CEA 2R2M 25NP
AWM-031 C34 2.2 25V CEA 2R2M 25NP
AWM-031 C35 2.2 25V CEA 2R2M 25NP
AWM-031 C36 2.2 25V CEA 2R2M 25NP
AWM-031 C37 2.2 25V CEA 2R2M 25NP
AWM-031 Q1 2SC1312-F
AWM-031 Q3 2SC1312-F
AWM-031 Q4 2SC1312-F
AWM-031 Q15 2SC1312-F
AWM-031 Q16 2SC1312-F
AWM-031 Q19 2SC1312-F
AWM-031 Q20 2SC1312-F
AWM-031 Q2 2SA725-F
AWM-031 Q5 2SA725-F
AWM-031 Q6 2SA725-F
AWM-031 Q17 2SA725-F
AWM-031 Q18 2SA725-F
AWM-031 Q7 2SC1312-G
AWM-031 Q8 2SC1312-G
AWM-031 Q9 2SC1312-G
AWM-031 Q10 2SC1312-G
AWM-031 Q11 2SC1312-G
AWM-031 Q12 2SC1312-G
AWM-031 Q13 2SC1312-G
AWM-031 Q14 2SC1312-G
LOGIC UNIT AWM-032
AWM-032 C1 0.68 25V CSSA R68M 25
AWM-032 C2 0.68 25V CSSA R68M 25
AWM-032 C5 0.1 25V CSSA OR1M 25
AWM-032 C6 0.1 25V CSSA OR1M 25
AWM-032 C9 3.3 50V CEA 3R3P 50
AWM-032 C10 3.3 50V CEA 3R3P 50
AWM-032 C11 3.3 50V CEA 3R3P 50
AWM-032 C12 3.3 50V CEA 3R3P 50
AWM-032 Q1 2SC1312-G
AWM-032 Q2 2SC1312-G
AWM-032 Q3 2SC1312-G
AWM-032 Q4 2SC1312-G
AWM-032 Q5 2SC1312-G
AWM-032 Q6 2SC1312-G
AWM-032 Q7 2SK30A-GR
AWM-032 Q8 2SK30A-GR
AWM-032 D1 1S188FM-1
AWM-032 D2 1S188FM-1
AWM-032 D3 1S188FM-1
AWM-032 D4 1S188FM-1
AWM-032 D5 1S2473
AWM-032 D6 1S2473
AWM-036 C1 0.1 25V CEA 0R1P 25
AWM-036 C2 0.1 25V CEA 0R1P 25
AWM-036 C11 0.1 25V CEA 0R1P 25
AWM-036 C12 0.1 25V CEA 0R1P 25
AWM-036 C5 10 25V CEA 100P25
AWM-036 C6 10 25V CEA 100P25
AWM-036 C16 10 25V CEA 100P25
AWM-036 C26 10 25V CEA 100P25
AWM-036 C13 4.7 25V CSSA 4R7M 25
AWM-036 C14 4.7 25V CSSA 4R7M 25
AWM-036 C31 4.7 25V CSSA 4R7M 25
AWM-036 C17 33 50V CEA 330P 50
AWM-036 C19 33 50V CEA 330P 50
AWM-036 Q1 2SC1312F
AWM-036 Q2 2SC1312F
AWM-036 Q3 2SC1312F
AWM-036 Q7 2SC1312F
AWM-036 Q8 2SC1312F
AWM-036 Q9 2SC1312F
AWM-036 Q10 2SC1312F
AWM-036 Q4 2SC1318R
AWM-036 Q5 2SC1318R
AWM-036 Q6 2SA720R
AWR-024 C14 220 35V CEA221P 35
AWR-024 C16 220 35V CEA221P 35
AWR-024 C17 220 35V CEA221P 35
AWR-024 Q1 2SD313-E
AWR-024 Q2 2SD313-E
AWR-024 Q3 2SC945-Q
AWR-024 D1 SR3AM-4
AWR-024 D2 SR3AM-4
AWR-024 D3 SR3AM-4
AWR-024 D4 SR3AM-4
AWR-024 D5 SR3AM-4
AWR-024 D6 SR3AM-4
AWR-024 D7 SR3AM-4
AWR-024 D8 SR3AM-4
AWR-024 D9 SIB01-01
AWR-024 D10 SIB01-01
AWR-024 D11 SIB01-01
AWR-024 D12 WZ130
AWS-025 D1 1S188FM-1
AWS-025 D2 1S188FM-1
AWS-027 D1 1S188FM-1
AWS-027 D2 1S188FM-1
AWS-041 D1 1S188FM-1
AWS-041 D2 1S188FM-1
AWS-042 D1 1S188FM-1
AWS-042 D2 1S188FM-1
MISC PARTS
C3 4700 50V ACH-16-A
C4 4700 50V ACH-16-A
C5 4700 50V ACH-16-A
C6 4700 50V ACH-16-A
Hello everyone,
I have been working on my replacement cap/transistor list and noticed after reviewing the posts, that nobody lists diodes for replacement. Should I worry about replacing the diodes?
In my SM I have multiple different transistors listed. Do I need to find a replacement for each one or are there just a few known bad ones that I need to concentrate on for replacement.
Thank you for your help. Todd
Sorry, I missed your revised post and it just receded into the past, dropped through the cracks...
Generally we leave the diodes alone, not many fail to begin with, so we don't worry about them.
The transistors I will have to examine along with the schematic and do some reverse engineering for finding appropriate substitutes.
I will be inhaling the data you posted into a spreadsheet and starting work on it. It will be a fair piece of work, and the clock has just only STARTED running...
edit - got it in (7:40 pm, took longer than I expected!!!) and FYI, there's a lot of parts in the list that don't need to be changed out... THAT list was quite a bit of work...
Mark,
Thanks for your help. I have been going through the posts to find the appropriate part numbers for the replacement caps. I will put them in a spreadsheet and post what I come up with so you can look at it to see I made any mistakes. I am completely lost when it comes to proper transistor choices so any help that you give would be great. Thanks again. Todd
caps go in the spreadsheet quickly once I sort out the film cap replacements, low noise and bipolar caps (and there ARE some bipolar caps in there!!), and I can't lift your choices...
I have THAT part down to an art, but I WILL be evaluating Pioneer's voltage choices for the caps, as well as stocking levels and cost.
word - tuner will get minimal work - no transistors, diodes and only a few select caps.
Mark,
I worked last night to convert the list into an excel spread sheet format so that ordering will be easier. I don't know if it will help or make your process of digesting the list harder. I also included some of the recommended part numbers that I found in other cap lists.
Hope this is useful.
Todd
Misc Parts
C3 4700 50v ACH
C4 4700 50v ACH
C5 4700 50v ACH
C6 4700 50v ACH
FM/AM Unit AWE-015
C2 0.47 50V cea 647-UPW1HR47MDD
C38 0.47 50V cea 647-UPW1HR47MDD
C61 0.47 50V cea 647-UPW1HR47MDD
C23 4.7 25V cea 647-UPW1E4R7MDD
C29 4.7 25V cea 647-UPW1E4R7MDD
C54 4.7 25V cea 647-UPW1E4R7MDD
C27 1 50V cea 667-ECQ-V1H105JL film
C58 1 50V cea 667-ECQ-V1H105JL film
C30 1 50V cea 667-ECQ-V1H105JL film
C33 100 16V cea 647-UPW1E101MED
C65 100 16V cea 647-UPW1E101MED
C36 10 16V cea UPW1C100MDD
C45 10 16V cea UPW1C100MDD
C53 0.47 25 cssa 598-DSF050J474
C55 3.3 16v cssa 647-UKL1H3R3MDD1TA
C57 3.3 16v cssa 647-UKL1H3R3MDD1TA
C66 2.2 16v cssa 647-UKL1H2R2MDDANA
C67 2.2 16v cssa 647-UKL1H2R2MDDANA
C73 47 16V cea 647-UPW1C470MDD
Q1 2sc738-d
Q2 2sc738-d
Q15 2sc738-d
Q3 ta7060p-gr
Q4 2sc738-p
Q13 2sc738-p
Q5 ta7060p-bl
Q6 ta7060p-bl
Q7 2sc711-f
Q8 2sc711-f
Q9 2sc711-f
Q10 2sc711-f
Q11 2sc711-f
Q14 2sc711-f
Q18 2sc711-f
Q20 2sc711-f
Q12 2sc382
Q16 2sk30-a
Q17 2sc870-f
Q19 2sc968-y
Q21 m5109p
Head Amp Unit W21-002
C1 22 10v cea 647-UPW1H220MDD
C2 22 10v cea 647-UPW1H220MDD
C3 4.7 16v cea 647-UPW1E4R7MD
C4 4.7 16v cea 647-UPW1E4R7MD
C5 10 25v cea 647-UPW1E101MED
C6 10 25v cea 647-UPW1E101MED
C15 220 25v cea 647-UPW1V221MPD
Q1 2sc458lg-b
Q2 2sc458lg-b
Q3 2sc458lg-b
Q4 2sc458lg-b
Q5 2sc458lg-b
Q6 2sc458lg-b
Mic Amp Unit W21-003
C1 10 10v cea 647-UPW1C100MDD
C2 10 10v cea 647-UPW1C100MDD
C11 10 10v cea 647-UPW1C100MDD
C12 10 10v cea 647-UPW1C100MDD
C7 0.47 25v cssa 598-DSF050J474
C8 0.47 25v cssa 598-DSF050J474
C15 100 35v cea 647-UPW1H101MPD
C16 100 35v cea 647-UPW1H101MPD
Q1 2sc1344 512-KSC1845FTA
Q2 2sc1344 512-KSC1845FTA
Q3 2sc1344 512-KSC1845FTA
Q4 2sc1344 512-KSC1845FTA
Control Amp Unit AWG-013
C3 47 50V cea 647-UPW1H470MED
C4 47 50V cea 647-UPW1H470MED
C21 47 50V cea 647-UPW1H470MED
C22 47 50V cea 647-UPW1H470MED
C9 100 6v cea 647-UPW1A101MDD
C10 100 6v cea 647-UPW1A101MDD
C19 100 6v cea 647-UPW1A101MDD
C20 100 6v cea 647-UPW1A101MDD
C13 4.7 25V cea 647-UPW1E4R7MDD
C14 4.7 25V cea 647-UPW1E4R7MDD
C15 10 25v cea 647-UPW1H100MDD6
C16 10 25v cea 647-UPW1H100MDD6
C24 2.2 25v cssa 647-UKL1H2R2MDAANA
Q1 2sk30a-gr
Q2 2sk30a-gr
Q3 2sa725-g 512-KSA992FBU
Q4 2sa725-g 512-KSA992FBU
Q5 2sc1312-g 512-KSC1845FTA
Q6 2sc1312-g 512-KSC1845FTA
Main Amp Unit AWH-015
C1 0.47 25v cssa 598-DSF050J474
C2 0.47 25v cssa 598-DSF050J474
C23 0.47 25v cssa 598-DSF050J474
C24 0.47 25v cssa 598-DSF050J474
C7 220 10v cea 647-UPW1A221MED
C8 220 10v cea 647-UPW1A221MED
C11 100 50V cea 647-UPW1H101MPD
C12 100 50V cea 647-UPW1H101MPD
C19 22 6v cea 647-UPW0J220MDD
C20 22 6v cea 647-UPW0J220MDD
C21 220 50v cea 647-UPW1J221MPD6
Q1 2sa726-gw 512-KSA992FBU
Q2 2sa726-gw 512-KSA992FBU
Q3 2sa726-gw 512-KSA992FBU
Q4 2sa726-gw 512-KSA992FBU
Q5 2sc1124-2
Q6 2sc1124-2
Q7 2sc1157-d
Q8 2sc1157-d
Q9 2sa647-d
Q10 2sa647-d
Q11 2sc1402-r
Q12 2sc1402-r
Q13 2sa744-r
Q14 2sa744-r
Protection Unit 1 AWM-028
C3 470 6V cea 647-UPW0J471MPD
C4 470 6V cea 647-UPW0J471MPD
C5 4.7 25V cea 647-UPW1E4R7MDD
C6 100 16v cea 647-UPW1E101MED
Q1 2sc857k-a
Q2 2sc857k-a
Q3 2sc945q 512-KSC2383Yta
Q4 2sc945q 512-KSC2383Yta
Q5 2sa733q
Q6 2sc945q 512-KSC2383Yta
Q7 2sc1384-r 512-KSC2690AYS
Protection Unit 2 AWM-029
Q1 2sc857k-a
Q2 2sc857k-a
Decoder Unit AWM-031
C1 0.33 25v cssa ECQ - V1H334JL
C2 0.33 25v cssa ECQ - V1H334JL
C16 1 25v cea 647-UPW1H010MDD
C17 1 25v cssa 647-UKL1H010KDDANA
C18 1 25v cssa 647-UKL1H010KDDANA
C19 1 25v cssa 647-UKL1H010KDDANA
C26 2.2 25v cssa 647-UKL1H2R2MDAANA
C27 2.2 25v cssa 647-UKL1H2R2MDAANA
C28 2.2 25v cssa 647-UKL1H2R2MDAANA
C29 2.2 25v cssa 647-UKL1H2R2MDAANA
C30 2.2 25v cssa 647-UKL1H2R2MDAANA
C31 2.2 25v cssa 647-UKL1H2R2MDAANA
C32 2.2 25v cea 647-UPW1H2R2MDD
C33 2.2 25v cea 647-UPW1H2R2MDD
C34 2.2 25v cea 647-UPW1H2R2MDD
C35 2.2 25v cea 647-UPW1H2R2MDD
C36 2.2 25v cea 647-UPW1H2R2MDD
C37 2.2 25v cea 647-UPW1H2R2MDD
C38 100 35v cea 647-UPW1H101MPD
Q1 2sc1312-f 512-KSC1845FTA
Q3 2sc1312-f 512-KSC1845FTA
Q4 2sc1312-f 512-KSC1845FTA
Q15 2sc1312-f 512-KSC1845FTA
Q16 2sc1312-f 512-KSC1845FTA
Q19 2sc1312-f 512-KSC1845FTA
Q20 2sc1312-f 512-KSC1845FTA
Q2 2sa725-f 512 - KSA992FBU
Q5 2sa725-f 512 - KSA992FBU
Q6 2sa725-f 512 - KSA992FBU
Q17 2sa725-f 512 - KSA992FBU
Q18 2sa725-f 512 - KSA992FBU
Q7 2sc1312-g 512-KSC1845FTA
Q8 2sc1312-g 512-KSC1845FTA
Q9 2sc1312-g 512-KSC1845FTA
Q10 2sc1312-g 512-KSC1845FTA
Q11 2sc1312-g 512-KSC1845FTA
Q12 2sc1312-g 512-KSC1845FTA
Q13 2sc1312-g 512-KSC1845FTA
Q14 2sc1312-g 512-KSC1845FTA
Logic Unit AWM-032
C1 0.68 25v cssa 647-UKL1HR68MDDANA
C2 0.68 25v cssa 647-UKL1HR68MDDANA
C5 0.1 25v cssa ECQ - V1H104JL
C6 0.1 25v cssa ECQ - V1H104JL
C9 3.3 50V cea 647-UPW1H3R3MDD
C10 3.3 50V cea 647-UPW1H3R3MDD
C11 3.3 50V cea 647-UPW1H3R3MDD
C12 3.3 50V cea 647-UPW1H3R3MDD
C17 0.47 25v cssa 598-DSF050J474
C18 10 16V cea 647-UPW1C100MDD
C19 47 50V cea 647-UPW1H470MED
Q1 2sc1312-g 512-KSC1845FTA
Q2 2sc1312-g 512-KSC1845FTA
Q3 2sc1312-g 512-KSC1845FTA
Q4 2sc1312-g 512-KSC1845FTA
Q7 2sk30a-gr
Q8 2sk30a-gr
Reverb Amp Unit AWM-036
C1 0.1 25v cea
C2 0.1 25v cea
C11 0.1 25v cea
C12 0.1 25v cea
C5 10 25v cea 647-UPW1H100MDD6
C6 10 25v cea 647-UPW1H100MDD6
C26 10 25v cea 647-UPW1H100MDD6
C13 4.7 25 cssa UKL1H4R7KDDANA
C14 4.7 25 cssa UKL1H4R7KDDANA
C31 4.7 25 cssa UKL1H4R7KDDANA
C17 33 50v cea
C19 33 50v cea
Q1 2cs1312f 512-KSC1845FTA
Q2 2cs1312f 512-KSC1845FTA
Q3 2cs1312f 512-KSC1845FTA
Q7 2cs1312f 512-KSC1845FTA
Q8 2cs1312f 512-KSC1845FTA
Q9 2cs1312f 512-KSC1845FTA
Q10 2cs1312f 512-KSC1845FTA
Q4 2sc1318r
Q5 2sc1318r
Q6 2sa720r
Power Supply AWR-024
C11 1000 50v ceb 647-UPW1H102MHD
C12 1000 10v cea 647-UPW1A102MPD6
C13 220 50v cea 647-UPW1J221MPD6
C14 220 35v cea 647-UPW1V221MPD6
C16 220 35v cea 647-UPW1V221MPD6
C17 220 35v cea 647-UPW1V221MPD6
C15 100 16v cea 647-UPW1E101MED
Q1 2sd313-e 512-KSC2073TU
Q3 2sc945-q 512-KSC1845FTA
Bump!
Any update on this list? Did you Recap it yet?
Once the list is vetted I will add a link to this thread on my "Recap list" thread! (Looks like I will need to add in a Quad receiver section!) :thmbsp:
