Thanks. I'd much rather not go drilling into the PCB... I still come up with 15mm when I measure the hole spacing, but I can see how 12.5mm will work well enough. My best option then looks like a nichicon KW:
UKW1J682MRD
Just to make sure I get all of them, the P/S capacitors I'm replacing in the 410 are:
C469: 470uF/50V...Nichicon KZ 470/50
C470: 100/35...Nichicon KZ 100/50
C471, 472, 475, 478: 47/50...Nichicon KZ 47/50
C476, 477: 6800/45...Nichicon KW 6800/63
C479: 33/6.3...Nichicon FG 33/16
C480: 33/16...Nichicon FG 33/16
Should I also replace C411 and 412 (4.7/35) ?
On the 620...Mostly Nichicon FG as I will be sending this receiver off:
C623, 624: 6800/45...Nichicon KG snap-in 6800/50
C802: 1000/50...Nichicon FG 1000/50
C803, 809, 810: 100/50...Nichicon FG 100/50
C804, 806, 807: 47/25...Nichicon FG 47/25
C805: 470/25 BP...Nichicon ES 470/25
C825, 826: 10/16...Elna Silmic II 10/16
C820: 47/6.3...Nichicon FG 47/10
C808: 220/16...Nichicon FG 220/16
C811, 812: 100/63...Nichicon FG 100/63
C813, 814: 22/25...Nichicon FG 22/25
C815: 4.7/35...Nichicon FG 4.7/50
C816: 33/16...Nichicon FG 33/16
Am I missing any?
