Sleep
Well-Known Member
Here is a picture borrowed from another A 960 thread. On the board at the top of the pic, the phono switch/stage is on the right. The blue track on the right passes between the silvery/white components I'm talking about, two on the left and two on the right. They are near the front of the board and lean away from the blue track at an angle.
If this isn't the problem, I don't know what is. It's somewhere to start at least! Hope works wonders.
I've fixed a bad solder joint before, but not a trace that's broken right beside a solder joint. Time to learn I guess.
