I bought a dead, untested CA-2010 ... it turned out a bit more dead than I'd have liked.
The two big power capacitors are missing. The board that houses the big caps has a black burn mark and it seems to have burnt off around the space that would be between the two caps. I mean, there's a sort of hole there with black marks around it.
The previous owner has 'reconfigured' some of the wiring to that board perhaps in an attempt to test or fix. I think with the help of a schematic or pics of some internals I can restore the wiring - not many wires ... about 6.
I don't know if I can get a replacement board (or if someone can create one for me) but it's a simple enough board so I 'could' put new caps in and jumper any broken wiring.
However, given the nature of the problem, most likely there are other issues in the amp ... one or more power transistors and possibly other components as well. By the time it's all done, the costs could be quite high.
I cannot 'see' any other issues in the amp so I may get lucky ... but seriously, I have limited talent and skills with a meter and an iron. This one may be bigger than I can tackle ...
So (and I realize the answer will tend to lean a certain way given the question is in the Yamaha forum) ... is it worthwhile even attempting to fix this. I'm a little daunted right now and am thinking selling it for parts may be the better option.
