Sleep
Well-Known Member
Hi all. Just picked up an a-960 integrated this week, and I'm in the process of getting it in shape again.
I've cleaned out the dust and crud, fiddled with the "Main Direct" switch and sprayed the volume pots with DeOxit. I'm about to set the idle current and DC offset in a few minutes.
That leads me to my 1st question...I get some crackling when I switch between different loads on the phono knob. Is it OK to spray DeOxit on the switch mechanism at the back of the unit? The part that's connected to the knob by a blue 'track' with a metal band inside?
Next question - I notice that when I have phono 1 set to 47k ohms, the right channel is louder than the left. I should mention that I have a HOMC cartridge on my TT right now, a Denon DL-110, and that it sounds balanced between left and right when the load is set to 100 ohms (the manual recommends that setting for HOMC carts). I thought it odd that it doesn't seem to work right when it's on 47k ohms, since that's what a lot of people would have as a MM phono input. Maybe the DeOxit will fix this, but will also try on the 47k phono 2 input.
As for the Main Direct switch...mine wasn't working. It wouldn't stay depressed 99% of the time. I found a thread here recommending a replacement switch for this, but since my desoldering skills aren't that great, I thought I'd try and fix it some other way.
After staring at the thing and poking the switch a bunch of times, it occurred to me that the spring on the outside of the switch shaft might be too strong. I used the tip of a screwdriver to hold a couple of coils so that they weren't pushing with the spring, and what do you know, it stays in now! So I snipped about 1.5 coils out of the spring. It works now, but I'm looking to replace the spring with a lighter one, as the unfinished end of the spring gets hung up on the switch body now and then. Still, it's a quick and free fix in this case.
