Hello All,
Long-time 'reader' but first time poster, and I hope someone can help.
I have been happily enjoying my CA-810 amp for the past year or so, with no issue. However, I recently picked-up a cosmetically beautiful CR-1020, that, unfortunately, seems to have an issue...
Using speakers, output from Right channel is clean, clear and strong. There is no output from Left speaker. This is reflected in the meters, where I see the right watt meter moving, but do not see anything from the left meter. If I move speaker selection to 'off' and crank the volume, I see the right meter almost pegged, while I see just a bit of movement in the left meter. Interestingly, when using headphones, I hear volume on both sides (with meters moving about the same distance)...BUT...at a very low db, AND if I move the balance to left, I hear nothing.
I've Deox'ed what I could, and no obvious switch problems...Dolby is "off", Coupler is "on", etc.
Any thoughts at all would be greatly appreciated! She is a real beauty, and I am really looking forward to hearing her how she should sound!
Thanks for any advice...
