kenneth501
I'm new to this but on a steep learning curve. My sx1010 was dead but after looking at the many posts I have replaced all caps and transistors on the power supply board, and both power amp boards. It now fires up and the protection works as it should. The left channel seems to be ok but the right channel crackles and is not as it should be. I can increase the volume with no cut outs.
When I measure the output on the power amp boards I am getting 12.5v on pin 13 which should be -0.6 on the right channel. Pin 10 is correct.
The left channel board reads as it should, the discrepancy is in the right board.
Have checked resistors R25,26,27, and 28 and all read correctly.
Have attached schematic as I am sure it may be something simple that with my inexperience I have missed.
