If you can control the RF level then it might be useful. You need a RF SG to be able to peak the coils and trim the var caps at either end of the scale.
Like Mark is asking, need to figure out what it is and not doing then we can figure out a coarse of act.
John,
Do the quad null test, short one of the FM inputs, 300 ohm or 75 ohm, then tune to a place on the dial that only picks up noise, is the center-tune meter centered? If not, you have to adjust primary core of T6, bottom core for center or as close to 0 volts across R26(510ohm). Not sure if you can access the bottom slug underneath or you have to place the tuning tool in the top, engage the top slug then let the tool go down to the bottom slug and have to turn slightly back and forth so that the tool engages the bottom slug, ( remember or mark how much you had to move the top slug, center the meter using the engaged bottom slug, then lift the tool back up to dis-engaging the bottom slug, and then put the top slug back into the position where it was originally. Now you are supposed to adjust the top slug for minimum thd, and then go back to the being as the two slug interact a bit. You can try Marks method but I cna not say I have ever done it that way, only used instruments. Just keep track of where the top slug was originally, phew make sense guys?
