neobop
Well-Known Member
ok now I need some help with the setup on my Phono stage/cart loading.
2 things:
1) The phono inputs on my Kyocera A-710 has a switch that is labeled "Input IMP" it has two settings, High and Normal. Currently is set to Normal. I would have expected this to be related to capacitance. Maybe it is? any ideas?
2) The Phono Stage has loading settings for MM and MC. My AT-OC9ML/II spec says ideal loading is 20 Ohms. My Phono Stage has 10 Ohms, 40 Ohms and 100 Ohms on the MC setting. Whats better? 10 Ohm or 40 Ohm? If anything I would like to tame the highs a bit, which setting should do that?
I have played around with all of this but have not as of yet settled on what I like the most. Just curious what the conventional wisdom would be on ideal setup.
First off, congratulations on your new table. It's a beauty.
Frequency response shouldn't change with loading a LOMC straight in. If it does and sounds bright/harsh, then you're getting an RFI like noise. Not much you can do except load it as low as necessary.
Conventional wisdom says capacitance loading doesn't matter with a LOMC, because it's immune. Conventional wisdom is wrong. Capacitance has the affect of lowering high frequency resonance of a cart and making overload potential more likely. It's an overload/oscillation situation which intermodulates and causes the harsh sound. The OC9 measures flat as a pancake otherwise.
Here's an interesting discussion on the topic:
http://forum.audiogon.com/cgi-bin/fr.pl?eanlg&1424065925&openfrom&1&4#1
neo
