Electone
Well-Known Member
This is a direct-drive, quartz lock, semi-auto table. I'm having a weird issue. I get a very low-level hum (not audible when listening to an album) and a static when the platter starts spinning (whether under its own power or just manually spinning it by hand). If you touch the center spindle, the hum completely disappears. I have checked and tightened all the ground wire screws, I have a good ground to the amp and the tonearm wires are all good and tight at the cartridge. Any ideas?
