MJ21193G & MJ21194G Mouser or Digikey
does it not matter about them being a lot slower ?
Hell yes..Advertised 120 WPC -- Typically measure around 155+WPC @ 1khz - 8 ohm load before clipping.I would assume that an M-4 is worth fixing
If any of you were going to repair an M-4 with a blown channel, is it right to assume you would replace the outputs in both channels? Or leave the good one alone? I'm trying to decide whether I should buy one with at least one channel out. It looks to be about $25/channel for output transistors and who knows what else including caps. I can imagine a $100 parts bill pretty quickly.
Thanks,
John
Thanks,
John
