asech
I picked up a Fisher 100T today that also came with a Fisher MPX100. I wanted the MPX to go with my TA600....anyway..
The Fisher 100T already has the MPX50 installed and after some checking and running it with the light bulb circuit the 100T came alive....
I decided to run it through the AUX on a 500B to hear how it sounds and was
amazed how much better it sounds than the 500B alone. The FM is clear and with depth and I hooked an MP3 through the 100T and had so much ...more!
I did a side to side comparison and was impressed with the 100T. The preamp let me really dial in the sound and would like incorporate the 100T with an amp.
This even with the 100T having a leaky filter can and a few leaking caps(it's turned off good until the overhaul)
My problem is I have only intergrated amps X202B and KX200, is there any advantage-disadvantage of using them instead of just a power amp. I do like the sound of 7591 tubes...
thx
thx
