Start at "ground zero".
Once you get a SM in hand, check the power supply voltages.
FWIW, odd voltages scattered around, or all over the place can be....
Bad ground.
Bad component leading to ground (resistor, diode, cap,...)
A messed up power regulator can make things confusing also.
