TheCodeDawg
I recently stumbled upon a cr2040. Spec wise, it is similar to my beloved sx1050, so I was intrigued and bought it from the Goodwill. It's a beautiful machine for sure. I ran home and plugged it into my dim bulb tester with no load on the speaker ports. Uh oh. What's that buzzing sound? The protection relay was opening and closing a a rate approaching 60hz. Off to hifiengine for the service manual. Out came the Fluke MM. First, an inspection of the power/speaker board showed a split resistor. The MM showed 2 bad switching diodes. I also removed the relay. The solenoid works fine and the resistance was .1ohm with the contacts closed. Put it back in and fired her up. No more chatter from the relay. And I had plugged in speakers. But wait. Since when does a protection relay open with the power switch? It also had the loud pop when turned on and off. (Note: ALL the lamps were fried) I groked the forums for this issue and found lots of advice. I replaced the 100, and two 33uf caps and the 3 npn and 1 pnp transistor. (Many thanks to Luddite Electronics in Longmont, CO for having them in stock) Now the protection relay works properly and no popping sounds at start and stop. however...
There is no output to the speakers other than a slight hum. Also, there is a popping sound followed by the protection relay opening. The 1/2 power and overload LEDs flash as well. I am not sure where to begin trouble shooting this. I also have an oscope. HELP!
