May I request some help with a SX-1280 tuner issue? I picked up a 1280 (basically working) for $250. Works well after a good Deoxit cleaning. The FM tuner signal strength is average. The tuning meter barely deflects to the left, mostly to the right. In addition, the meter is not centered (slightly to the right), even when powered off. I adjusted T6 on the tuner PCB per the manual, but could not adjust it far enough. From a powered off state, should I start by centering the tuning meter? I assume there is an adjustment screw below the face. If so, how can I remove the meter assy from the front plate? Any other overall ideas? Thanks!!
