Taken in to account that all three will need calibration and cosmetic clean up etc.
and if the primary tubes being checked are
KT88 EL34 KT77 KT90 ( and other variation from these types)
12au7 , 12ax7, 6922, 6DJ8 , 12BH7(a)
EL84 etc etc
The TESTER contenders being
Hickok 600
Hickok 800A
Hickok 6000
which seem to all be fairly similar. If you had to choose only 1 ( unless there's some pressing benefit to own 2 other than for back-up and the love of hoarding).
which would you choose and why?
also where on the web can I find the most up to date manuals and Tube "roll chart" information for these testers? The plan is to just print it out and put it in a binder instead of futzing around with the roll chart on the unit ( which is out of date and missing a few of the tubes I most commonly use).
and finally... Who is the best "reasonably priced" repair tech / tester guru to send a Hickok tester to be refurbed / calibrated etc..
EL84 etc etc
Hickok 600
Hickok 800A
Hickok 6000
