cr-640 only outputs in mono
se7en8n9ne
Hey there guys,
So I gave my friend my cr-640. By the time I got it across town and hooked it up it only played in mono and I had used just fine about 2 months prior.
Any ideas? Any help appreciated. Thanks guys
Do you mean that only one channel plays, or that both left and right channels play but they sound exactly the same?
Hey there guys,
Get the deoxit out.:thmbsp:
i mean i only get sound when the speakers are plugged into - A left channel - and - B right channel - and the stereo is switched to mono.
i'll check the connections when i get home. thanks
When you switch it to stereo, does it play out of just one speaker? But both when you switch to mono? If so, that probably means that it's not a bad amp chip.
