RJolly87
Well-Known Member
Spawned off of this thread:
http://www.audiokarma.org/forums/showthread.php?t=612470
Pictures that I have:
This is what I know (most of which is mentioned in the previous thread):
Cabinet is 14" wide, 23.5" tall, 12.5" deep, excluding the front trim.
12" woofer, Horn tweeter outlet is 9.5" x 2.5", and spans horizontally across the top. No ports or additional drivers have been located.
There is also what appears to be a cone shape deflector 4" in diameter mounted in front of the woofer, with two sets of numbers, SP2, and 140401-1
Weight is moderate for their size
Speaker wire is integrated, and comes out the lower left corner of the back.
10 screws surround the perimeter of the back panel, however there also seems to be something else sealing the back panel. There is no apparent way in or out of the cabinets.
An early suggestion was given of 1970's vintage Heathkits, however it seems that they oriented the few horn tweeter setups they had differently. The setup reminds me of a configuration seen with Magnavox, but no luck there yet either.
Any help would be greatly appreciated. The is no markings or logos anywhere.
I will try and sweet talk the backs off.
