I just picked up this nice little system, knowing it was a "pig in a poke", but I was told it worked fine.
Quite a major hum going on. Much more in one channel than the other.
This is present whether in Phono, FM (no AM on this model) or Aux. Volume does not have any effect - it is constant.
I thought maybe a speaker problem, but tried a good speaker from another KLH system and no difference.
There is a switch on the back of the TT labeled IN/OUT (see photo, which is not mine, but one I grabbed from online). I wonder if this is to switch from speakers to headphone (1/4" jack. I haven't tried the headphone option as I don't have any). The hum is present with the switch in the IN position, but is not present when this switch is in the OUT position (in the OUT position there is no sound at all, as if I've shut off the system). By the way, the photo shows an AC plug jack with what appears to be a ground prong. Mine uses a hardwired AC in with no ground.
I haven't opened it up, but may. Just want to take it slow, and who knows, maybe it has a simple explanation.
What do you think? Simple issue? Easy fix?
EDIT: I just opened it up, and the problem seems very apparent. There is a large capacitor whose top has come off (see pic). I realize that some, as a matter of course, replace all caps from something of this vintage. I've never replaced a cap, but have done small soldering jobs on bass guitars and other light electronics. Is this something I can do? Or would it be better to take it in for repair (and where would I take it in the SF Bay Area?). Expensive repair?
Ideally, I'd like to repair it myself, but I don't know if I want to learn on this unit. And, well, caps...
Ian
SF Bay Area
Ian
SF Bay Area
