1moreamp, you seem extremely knowledgable about electronics repair in general so I have kind of a dumb question...
Are film caps a recent innovation? Because if they last forever, why is it that all these manufacturers of the Japanese, American and Danish electronics I love didn't use them in the first place!
Sorry... threadjack /off
Film caps have been around since tubes were invented. Tube amps have them in between the tube stages to block the 300 to 600 DC volts plate voltages present but to allow audio to pass to the next stage....
I have seen many amp makers use film caps explicitly just to render higher SQ similar to tube amp SQ. I can point you to many amp makers internal pics and they all use film caps whenever possible in audio pathways.
Film caps are:
1 more stable
2 live longer more trouble free lifespans
3 have tighter tolerances
4 do not dry out and leak like wet caps
5 less temperature sensitive in most cases
6 more expensive cost wise
7 are usually slightly larger then wet caps nowadays except for larger ufd capacitive values.
Wet caps are:
1 CHEAP !
2 SMALL
3 just reliable enough to survive most warranty periods by a fair margin
4 A usable band-aid in any emergency LOL LOL LOL...
Please bear in mind wet caps in any amps audio pathways serve ONE main purpose, and that is to Block errant DC voltage offsets associated with gain stage interconnections and between amp inputs from preamps and such.. There are other electronic reasons but this one listed above is the main reason. Other reasons may be low frequency roll off and inhibition of excessive low frequency information and DC voltage input to the amps next stage. basically frequency compensation of some sort..
All electronic amp gear uses caps between preamps and main amps inputs, and their main purpose is to block any errant DC fundamentals from being sent inside of the amp stage, and to also limit low frequency inputs also if designed with that intent in place. Mac uses these also, so don't shoot me for telling the truth its standard engineering since the beginning of time and small, cheap wet caps fit back then for many reasons explained below I hope....
With the advent of DC wide bandwidth amps came the possibilities of amplifying DC voltage also.
Now on Mac amps with their auto transformers this isn't as bad of deal as with regular DC < Direct Coupled > amps that have no transformer coupled output.
DC voltage presented to many amps inputs will be even larger DC output to a speakers passive crossover and or the low bass driver directly which will offset the drivers cone from its true center resting position...This also will cause excessive heating of the voice coils, and burn out of drivers, along with muddied up sounding bass and damaged cones and spiders possibly...
So DC voltage output is a bad thing if your woofer is standing a half inch off center of its X max home position.
Plus any DC voltage present will rob real power from the amps driving ability.
SO amp makers use DC blocking electrolytic caps on preamp outputs and on main amp inputs. Mac used these also, and due to Film caps of that Time era being rated for 400 to 600 volts for tube use, well they were just to dang big to place inside of these new solid state wonders.
Newer, smaller footprint film caps with 50 and 60 volts ratings are nothing really new but. But cost wise they have been an impediment of manufactures because bean counters get into the picture of many amps being brought to market and they cut back on money expenditures like film caps to save money and to use smaller wet caps < which fail with age and what not >
Wet capacitors are cheap, small, and will usually out last most base warranty consideration for electronics manufacture, except Chinese wet caps < they don't have the chemistry down yet, but they are trying to steal it from the Japanese, Europeans, and the Americans >.
So no no to Chinese wet caps always, just google bad caps and see their entire web site of bad Chinese wet caps...I will let you be the judge after seeing what i already know...
Film caps are dry caps, so no wet electrolyte to dry out or leak out. dried out caps short out internally and wet caps that leak well lets just say they destroy PC boards when they leak.
I have seen Wet caps leak and burn wholes right thru fiberglass PC boards.
Most film caps are considered to be Self healing as they tend to clear internal shorts in most cases. I have seen a few melt down so they are not fool proof, but IMHO they are a better choice for all the best of reasons...
My MC4000 had this problem in its power supply, < nice quarter sized hole in its PC board in it power supply from a leaking wet cap > so YES even Mac amps have bad wet caps in them < Now please don't hit me for saying that !!! lol lol lol... > Its just the plain true about cheap, small wet electrolytic caps....:yes:
So for better SQ and more reliable service work I use Film caps when and where possible, and to date have never had any bad feedback about it and the amps SQ.
I own dozens of amps, and one particular set of amps I own made by Phoenix Gold exclusively uses nothing but film caps in any of the audio circuitry. They do sound better then the rest of their gear they made IMHO..
PPI used a big 4.7 ufd film cap inside of each channel between the preamp sections and the main amp input and they sold millions of car amps because they sounded good to most folks.
Tube SQ had been characterized electronically speaking and a lot of it has been tracked back to the use of FILM type caps...
You be the judge, I did not invent this stuff. I just kept up with the technology so I would be a good engineering tech to all of my clients. Which many come to me just because I will upgrade all of their gear internally where others will not hassle with it...Hope some of this was useful and helps some of you in some way..........
Oh and dump all tantalum caps you ever run into on any gear. They have been the death of a many a piece of gear in my service history experiences...They never really lived up to engineering expectations for them.
Please forgive the thread-jack OP...
