Hard Bop
Member
What does 100% mean to you?
I already answered that earlier so let me pose the same question to you.
In terms of a singular percentage that describes this particular amp based on any or all information you have from this thread, what percentage would you assign to it? Next, now that we have that, explain exactly how did you arrive at this percentage? Is it rounded to only two or three digits? Or is it more precise? If rounded to only two or three digits, why so? Thanks, I await your sincere and vigorous reply.
I don't think you'll be happy sonically or with the repairable quality of those low cost tube amps. and if your on a budget have patience and fix what you have!
First buy some good tubes and a new PCB and then better output transformers(if needed) as that's what defines the final sonics of a tube amp if you have the circuit and tubes up to par. As I mentioned you can get good $ (maybe $200) for your old output trans. if need be and if you spend the $700-800 mentioned you will have sonically a Hi End tube amp on a budget.
Spending a lot on a new unit doesn't always get you top of the line Output Transformers either as you could be paying for the looks which is why I'm saying diy as and you mentioned possibly doing that. Anyway you've got a pretty foolproof setup to start with.
You already have a decent new condition chassis and really good (upgraded ) PS trans to work with. There are lots of good PCB 's with decent circuits for the Dynaco ST-70 which is a great advantage along with easy an easy to repair design that others understand also so there is lots of help there.
Tubes require lots of patience sometimes and so aren't for everyone either, but I like them due to their better sonics for the $ and easy repairability!
Thanks for the encouragement. You are encouraging in your attitude about these amps, and I appreciate it. I very well may build one at some point in the hopes of understanding them better. Maybe a Latino ST-120. Right now I work a lot though, not much time to screw around at home, and I think a factory built might be the better way to go, Rogue or Vincent probably.
I meant you shouldn't sell it at a discount price cause you'll lose money , I was encouraging you to bring it up to snuff to get your investment back- I guess you took it the wrong way. I've never bashed anyone in a forum about anything , was try to be encouraging.
Oh ok, well most here have been very encouraging and I appreciate that. A few are internet assholes for one reason or another, they come here because most people will tolerate them. Open discussion is one thing, but these people like to frequent places where they are more or less not held accountable for their aggression. Internet by its very nature yields to this group a little bit and supplies little pushback, so they flourish. Many years of using and in one case running another web board makes me well aware of these types and how to deal with them. Glad you are on the positive side, I am too, and internet behavior is after all another application of any normal code of ethical human behavior.
