Aspen
It seems my recently repaired R-900 (new right STK, few burnt resistors) has a new issue. The right channel has a noise that sounds like wind blowing. It's only on the right side and volume has no effect. At zero volume it is about 5 or 6db of noise vs the left which is dead quiet. It can be heard in the headphones on right side only. It was louder when I first noticed it and made the music on the right sound distorted with no bass.
I powered off for 10 minutes and it was inaudible when I switched on. Came back after 20 minutes or so. No effect if I change input sources, switch the coupler, or any other control.
Any ideas?:scratch2:
Bad capacitor?
Cold solder?
All input kindly appreciated. I was planning to get the tuner aligned, maybe I will have the tech go through it and recap some of it.
Bad capacitor?
Cold solder?
