shelly_d
Not An Audiophool
I bought my first Mac on that auction site. A distressed MA6200. The initial issue (I hoe the only one) is that the former owner removed the Tape Mon, Tape Dub, Speaker selector, power push buttons. I knew this going in. After I received it I found that the circuit board that they attached to was gone as well. So far its noting I did not expect. The seller was up front about the switches and I was hoping the circuit board was inside the amp but not really surprised it wasn't. My plan is a new DIY circuit board with replacement switches with a DIY mounting system. All of it I believe is doable. Will have to sacrifice the lockouts that the two dubbing and two monitor switches share but that deficiency is worth it to get this back in service.
Here are two pics of the inside of the amp where the circuit board went. I have removed the led indicator board to give myself a little more work room.
The help I need now is to get an image of a stock installation so that I can get some feel for the orientation of the switches and board in the amp so that I can lay out the board in Eagle in a way that actually makes sense.
Thank you all in advance.
Shelly_D
Shelly_D
