Gregory
Soundco Kid
Known issues
At least three AK'ers have an intermittent 2205 power meter, and IIRC they are all LEFT meters. Looking back through the threads and PMs, my meter cutout problem was going on BEFORE the 2205 restore/refurb activity. These meters have a known common issue. As Ron-C communicated in Dec 09, "It is a common problem in these meters which were used by McIntosh, ESS, Marantz, etc."
Here is a photo received from a user who replaced the meters in FOUR of his 2205's and apparently the end-caps as well. I'm a little worried at how tightly he's got them packed in there in terms of heat.
Photo of 2205 stack whose owner replace all eight power meters with MC7200 meters?
The MAIN SYMPTOM of the affected METER is that it's usually dead at power-up and requires a transient to `wake it up!!´
Meter voltage
According to McIntosh Service Tech Keevin the 2205 power meters are basically LARGE 1.5 Volt DC meters. A variable DC power supply could be used to test them, setting the output voltage arbitrarily low and being very careful not to over-drive of course. Here are some test data on the operation of the meters. You can see the very low voltage at which the meter will `cut out.´
Voltage across power meter vs dB reading, with cutout voltage indicated.
The drive voltage will roughly double (in this case) when the cutout occurs.
Meter resistance
If the RED wires were unsoldered from the Lamp Board pins the measured resistance across the meter movement should be ~2K ohms. That is another way to diagnose the problem.
Amplifier circuitry
Keevin at Mc also mentioned checking the ORANGE wires on the driver board to the HEADPHONES & METER DRIVER circuits but nothing unusual was found there. Going a step further, one can trace the meter signal path from the METER BOARD to the LAMP BOARD. Here is the diagram.
Sketch of MC 2205 power meter circuits through the amplifier.
There are many connections that could affect the varying DC meter voltage along the path end-to-end including the board edge connectors. One could wonder why such a route was used instead of adding tiny 2-conductors pin jacks on the meter PCB? That could be a possible Mod and would also reduce the number of conductors needed in replacing the Lamp PCB RIBBON with a wire bundle.
Diagnosis
Jumping right into the meters and popping them open can be a challenge. It's NOT too difficult to separate the clear meter covers using a FLAT bladed X-Acto knife. It's more about applying skillful prying action and not about `cutting´ through the adhesive which is very dry and brittle. The recommended approach is to diagnose first by remove the Black sheet-metal TOP COVER (four Phillips screws) then unsolder and swap the RED meter wires L for R. If the same meter still cuts out, it's likely the internal meter terminals. If the opposite meter cuts out, then the problem is likely upstream. {is that correct?}
Why the LEFT meter?
A question that keeps coming up is.. why does it always seem to be the LEFT power meter? Maybe the group can figure that out after doing more tests and thinking about the problem for a while. :scratch2:
-Greg
Meter voltage
Meter resistance
Amplifier circuitry
Diagnosis
Why the LEFT meter?
-Greg
