Where are the bulbs in the picture? If they are behind the large board going through the rubber grommets, they are probably the little white bi-pin lamps. you will need to unsolder the little circuit board and then unsolder the bulbs. Do the reverse to reinstall. This would be the time to substitute LEDs. Sorry, I don't know the lamp number. I am sure it is a common number available at Mouser for $2.00 or less.
