try1256
I am having a little problem with my source selector that I can't seem to solve.
I have my KLH TNE 7000a connected through Tape monitor 1 on the amp. When I listen through it, occasionally, one of the channels will get fuzzy or drop in volume. When I wiggle the switch, it will come back. I have cleaned the source and record select switch twice now to try to correct the problem but it still persists. Phono, tuner nor aux have exhibited this symptom. I don't believe it is the KLH unit because working the switch seems to correct it temporarily. Is there anything else in the circuit that could cause this? Thanks,
