Anybody got specs about an onkyo dynamic four 700 receiver???
4player
anto
picture.php
From a ONKYO flyer.
Solid State Compact Component Stereo System model 700
LAYOUT
A luxury room is not at all necessary for this component system, which allows for free Layout. An unity room is given unity by the high-fidelity sound. Many different layouts are available for excellent sound reproduction.
INPUTS
This enthusiast-oriented amplifier is rich in terminals. That is why a wide range of inputs can be engaged including tape decks, microphones and electric instru¬mentss as well as FM and AM broadcasts and records.
CONTROLS
However the components are arrayed, a sound field can be modulated accurately by using the tone controller. Conveniently fitted with the loudness Controller, balance adjuster and monaural-stereo selector switch.
LSPEAKERS
Additional speakers can be put to work by connecting them to external speaker terminals.
A headphone (optional) is the answer to neighbor's complaint about too much volume.
Multi-Purpose Solid-State Stereo-Receiver
High-sensitivity FM and AM tuners plus high-selectivity FM multiplex demodulator circuit.
Abundant input terminals and controls that permit multiple functions and applications.
Control panel and knobs in mat-silver finish that provide the accurate control required by the enthusiast.
(RECEIVER) CIRCUIT: Solid state AM/FM Multiplex stereo receiver,
SEPP OTL ITL circuit, 23 transistors, 22 diodes
DYNAMIC POWER: 28 watts (14 wattsX2)
FREQUENCY RANGE: FM 88--108 MHz, AM 530¬1,605 KHz
INTER MEDIATE FREQUENCY: FM 10.7 MHz, AM 455 KHz
SENSITIVITY: FM 3µV(IHF) AM 15,uV(IHF)
ANTENNA: FM lead antenna, AM ferrite antenna
OUTPUTS: MAIN SP Impedance 8 ohms, EXT SP Impedance 8 ohms
HEADPHONE Impedance 8 ohms
LINE/TAPE OUTPUT Output level 200mV, Impedance 100Kohms, DIN (OUT) Output level 300 mV, Impedance 20Kohms
AC OUTLET for record player
INPUTS: PHONO Sensitivity 170 mV, Impedance 1Mohms. LINE/TAPE INPUT Sensitivity 300 mV, Impedance 80 Kohms. DIN(IN) Sensitivity 300 mV, Impedance 80 Kohms. MIC Sensitivity 20 mV, Impedance 100 Kohms. FM ANT, AM ANT.
CONTROL: Tone, Loudness, Balance, Mode (Stereo »Mono)
OTHER FEATURE: FM mono » stereo automatically changed, FM stereo indicator, Tuning meter.
Michael-Otto
