elnaldo
Lunatic Member
SOLVED Amplifier gets into protection with no load
Is that a normal behavior?
I'm testing a pioneer sx-850 with no load, feeding a 135mV RMS 1000Hz sinewave to both channels (input sensitivity is rated 150mV), and the protection activates when volume knob reachs 2 o'clock. Turning down to 1 o'clock, it works again.
Tested with the scope, never goes into clipping, the protection activates before any signal clipping. Both channels driven, the signal looks perfect.
No DC at the outputs when clipping, I've just adjusted it to 0.2mV.
Protection board is receiving power. It's just doing it's job.
Should I proceed with a small load, let's say 15 ohm or more?
Edited: It's not a consistent fail: I've driven one of the channels to MAX volume without protecting itself. The other channel protects earlier, but once this happens, next time the protection activates earlier... I think I'll recap the protection board to trust it. I've replaced the differential pair this morning, DC offset looks perfect.
Thanks!
Thanks!
