Grim Reaper
What could be causing this problem? I have owned this CR2020 since new. Intermittently, the sound goes off and meters go wonky, the tuner needle goes far right and the right speaker needle goes to the middle. When I turn it off, it will sometimes not reset but usually does and works, usually for a while. Any guidance as to what could be causing the problem is appreciated.
