Can someone tell me if this amp has a common ground? Thanks N8
n8thesk8 Well-Known Member Mar 3, 2013 #1 Can someone tell me if this amp has a common ground? Thanks N8
clinic-audio all on YAMAHA untill 1990 Mar 3, 2013 #2 hello Do you have it in front of you ? If yes check the both black speaker terminals :thmbsp:
H hionfi Well-Known Member Mar 3, 2013 #3 The M80 is common ground, I used it with a pair of Polk SDA's.
n8thesk8 Well-Known Member Mar 3, 2013 #4 hionfi said: The M80 is common ground, I used it with a pair of Polk SDA's. Click to expand... Thanks. I want to hook it up to my SDA's.
