danny1968
I recently picked up a KA-7100 from Goodwill with the left channel sounding full and powerful and the right side is small and much lower volume. I have tested this with phono, tuner and aux inputs through speaker A, B and A+B and get the same results. Also tried switching from Tape A source to Tape B source. No change.
Should I start to look for bad components... maybe I can test the output transformers? I've got a multimeter and I'm not afraid to learn how to use it! Will a recap of the preamp section potentially fix such a problem? Maybe something else completely?
After doing some research here on AK I have decided I can probably clean and recap this amp as a way to learn troubleshooting and repair. I've been a sound engineer for 20 years, so I have some idea of how to proceed but still have lots to learn. I have already changed the power supply capacitors but since I've never done a recap before, I'm taking it slow.
Also, on another thread about a KA-7100 recap, it is recommended to change bypass capacitors. For this, the parts list references 4 x1uF film, 5989-100v1.0-F capacitors which I sourced locally. Problem is, I'm not sure where to find them! I have included photos with my guess as to where two of them are...
Thanks for looking!
Thanks for looking!
