david winter
Classical music lover.
Yamaha CR600 output stage rebuild - New transistor types
Hi,
I'm opening this new thread to be more searcheable (and hopefully useful) for those who would need some infos to replace transistors, although some types still need to be confirmed.
If any other model uses the same output stage, let us know. Always easier to have one thread for all...
I'm using the CR600 references (TRxxx) as per service manual.
I will also mention when a different type of transistor that what's in the SM was originally installed.
Any suggestion for good subs will be really appreciated.
Service manual is (temporarily) available here. Output section with schematic, placement and parts list is at pages 37 / 38.
Differentials:
TR701, TR702, TR703, TR704: 2SA572 (2SA763 on my board) -> KSA992
Bias:
TR705, TR706: 2SC1124 -> KSC2690AYS ??? BD139 ??? KSC3503DSTU ??? 2SD667 ???
TR707, TR708: 2SC458 -> KSC1845
Drivers:
TR709, TR710: 2SC1382 -> MJE182
TR711, TR712: 2SA682 -> MJE172
Outputs:
TR713, TR714: 2SD371 -> MJ15003, MJ15015 or MJ21194G (works great with this last one)
TR715, TR716: 2SB531 -> MJ15004, MJ15016 or MJ21193G (works great with this last one)
DC protection circuit:
TR717, TR718: 2SC458 -> KSC1845
TR719: 2SA572 (2SA763 on my board) -> KSA992
TR720: 2SC458 -> KSC1845
TR721: 2SA682 -> MJE172
Update log:
- 15-Jul-15: Confirmed the use of KSA992 and MJ21193/21194. Rest to be confirmed (any help appreciated).
- 08-Jul-15: Added another set of outputs. Still trying to know if which are best and if others, as suggested, are good enough.
- 26-Jun-15: Used 4seatPilot's outputs which are known to work great.
Hi,
Differentials:
Bias:
Drivers:
Outputs:
Update log:
