Hi,
I have an intermittent failure in the FM ratio detector stage of a TK-40SW that's been driving me nuts. :tears: The output on FM sometimes disappears although the tuning meter indicates that the signal is there. Usually happens when turning the set on after it has been off for a long time.
Since the meter works even when the ratio detector fails, I sniffed around the detector driver, Qb5. When things were working, the DC bias looked OK, but when the stage died, there seems to be no current flow in the transistor.
DC Bias Qb5:
Working: B:12.45V, C: 4.27V, E: 12.51V
Dead: B:12.12V, C: 0V, E: 14.44V (Equal to supply rail)
And here's the kicker - I found that repeatedly touching the base lead of this guy with a wire would often bring it back to life. I just can't figure out why this happens. :dammit:
I can't detect any microphonics which would indicate a cold solder joint. I banged the transistor and the board with a plastic tool and nothing happens - it either continues to work or continues to be dead.
So suspecting a parasitic oscillation I built a diode based RF probe and checked again. Absolutely no RF activity when the stage dies. I also tried probing with a frequency counter and even a wideband ICOM radio, but there is no sign of any oscillation when the stage malfunctions.
RF Probing Qb5
Working : B : 0.78V, C : 10V, E: 0.06V
Dead : B : 0.77V, C : 0.06V, E: 0.02V
Before going on a wild goose chase for prehistoric transistors on Fleabay I was wondering if the Gurus on this forum could give me an insight into what's going on. BTW the TK-40SW is a FM Mono receiver.
Thnx and Cheers,
Sant
DC Bias Qb5:
RF Probing Qb5
Thnx and Cheers,
Sant
