sawdust
Solid walnut covers all my gear
I started with the big 2200uf 100v and turned it on let it idle on the bench for 5 minutes than pulled the left amp and replaced all the caps and transistors and turned down VR2 to minimum and installed back in the amp fired it up on the DBT and set VR1 and VR2 than turned down VR2 and shut it off. Turned it on to full120v and set VR1 to 0mv and set VR2 to 50mv . Than I did the same thing to the right amp at this point both amp boards are back in and adjusted I was going to let it idle for 15 to 20 minutes to re check but after 2 or 3 minutes the 48v amp board relays kick off . I found that pin #1 on the meter board lost the 48v found a bad resistor R40 470ohm 2watt replaced and now it has 48v on pin 1 but when it is power on for 6 or 7 seconds it drops off . I took the right amp board out and fired it up with just the left in 6 or 7 seconds the relay closed and it worked knowing that left board worked it tried in the right after 6 or 7 seconds it lost the 48v on pin 1 on the meter amp board.
Both boards work if I put them on the left side neither of them will work on the right side . I took some measurements on the Meter amp AWM-113 and found no power coming out of pin 6 that goes to pin 10 on the right AWH-065 power amp board
Pins
1 46.9v
2 69.0v
3 69.0v
4 Ground
5 93.5V
6 0.001v
7 -0.065v
8 0.005 Right Meter
9 0.005 Right Meter
10 0.642v
11 19.94v
12 -0.015v
13 -0.061v
14 -0.002v
15 Ground
16 0.005 Left Meter
17 0.005 Left Meter
18 -69.2v
19 -69.2v
20 Ground
21 93.5v
Pins
1 46.9v
2 69.0v
3 69.0v
4 Ground
5 93.5V
6 0.001v
7 -0.065v
8 0.005 Right Meter
9 0.005 Right Meter
10 0.642v
11 19.94v
12 -0.015v
13 -0.061v
14 -0.002v
15 Ground
16 0.005 Left Meter
17 0.005 Left Meter
18 -69.2v
19 -69.2v
20 Ground
21 93.5v
