orionspants
Starting Out...
Good Day,
I recently got onto the vintage audio scene and picked up a few items, a QX-8000a which is functioning fairly well and a SX-838 which I got with the intention of tinkering with and possibly learning on since it was not functional.
After popping the SX open and giving it a thorough clean here is its condition:
*It has power, and there is power flowing to the Left channel speakers only,
*But there is no sound, tuner doesn't appear to work,
*once turned on you can here the static rise subtly in the left ch then something internal makes a soft click and the static cuts out, this can be repeated by turning it off and on again
I've visibly inspected all the fuses, which had some grime on them but appear fine, many of the contact points (or soldering points) have small little brass coloured spots (looks like tarnish) but show no other damage. In general the top half of the metal board (to which all component are attached)has lots of wear/oxidation but this appears isolated to the open metal portions where nothing is attached. underside is mint looking.
So is this a power supply issue? a Speaker relay issue? Or something else? I'm wondering if this is the sort of problem a complete novice could or should tackle? I don't really want to invest much in it as it's cosmetically fairly rough looking, probably not worth that much even if I was to get it humming again.
Still I wouldn't mind learning on it if it's not too complicated. Otherwise I will probably pull it appear and see if anyone needs the components (or should I just send it to the curb?)
Thanks for any advice or guidance!
