I determined the individual SX-1010 idle currents by starting with the current arrows that read 100mA @54v on the main schematic.
Since the same supply (2 big caps) is shared by both channels:
Two channels knocks it down to 50mA per channel
TWO OUTPUTS PER CHANNEL makes it 50 mA split between the two output pairs for 25mA
25mA pair pnp / npn pair through BOTH emitter resistors of 0.5 ohms each for a total of 1.0 ohms means 25mA reads as 25mV, and across ONE emitter resistor of 0.5 ohms it reads as 0.0125v for 25mA.
Now to address the 1250 systematically:
The 1250 has FOUR big capacitors, meaning each channel is fed individually.
EACH pair/side/channel has a notation of "200mA @ 70v".
The instructions direct to adjust for 100mV between terminals 7(+) and 19(-).
terminals 7(+) and 19(-) is a special summed set of measuring points for the 2 pairs of output transistors coupled to each of FOUR corresponding emitters by a 22 ohm resistor, if bypassing the summing network and instead going directly to the individual pair's emitters should yield approximately 100 mV, being slightly over or under due to component tolerances...
