palmer67
Member
Left channel distortion G-7000
The left channel sound is distorted and is also reflected with the VU meter showing lower output . I've cleaned the pots and switches . Checked connections inside the unit for any corrosion and found none . Tested both "A" and "B" speaker outputs and switched speakers all while getting the same distortion . Don't see any damage or burn marks on the boards. Whomever owned this before must have had some shoddy work done in other areas so lord only knows what is at fault . I have a number of pictures if needed ...of both the good and the bad ....:scratch2:
Cheers
Cheers
