A little quiet around AK's Pioneer Forum so I though I would post my Current Pioneer project.
I repaired a sx-770 for my Vietnam War Veteran friend last month. He had bought it when he was stationed there in the late sixty's. It was my first cap coupled amp repair and was a fun project. I had bought a donor 770 to complete the restoration, providing all the missing parts needed to make it perfect. The donor was missing the transformer, speaker terminal assembly and power cord. The serial number indicated it was a late model in the production run.
Having a spare donor, I went on a search for a broken 770 to restore and low-and-behold I found one. This one is an early model where the tuner board is quite-a-bit different. The pictures show the differences. Also, you'll notice I included a image of the donor unit's amp board using the replacement outputs.
Note to others:
When I started this hobby, I went for the big sets and soon realized they were a hand full. It took several years and help from the great members here on AK to figure out how to work on these beautiful sets. In retrospect I would of started on sets like these 770's and would of been a lot further ahead.
Late model tuner board:
Early model tuner board:
I started looking at the amp board for the project set. I have a Mouser order in for all the caps and transistors. I use standard equivalents we have been using here in the Pioneer Forum. 1220's, 2690's, 1845's and 1815's.
This Amp board is from the donor set. The previous guy used Motorola P41C917's for the outputs and modifing the back/trace side to make them work. A pretty good job was done but the outputs on the project set's amp board are in good shape.
Project set below. I am going to use the faceplate from the donor set as it is mint with no flaws. The bonnet will get veneered with a quartersawn walnut and should look pretty classy.
Note to others:
