I have a 5030, it does not sound so bad at all, do not know if sounds any better than my pioneer sx-950.
Problems with the power switch too!! arching, causing the dial lights to flicker. Had to take all apart and file the pits off the contacts.
I'll post a re-cap list I have been working on,never bought the parts so there maybe some errors.
Kenwood KR-5030/5330 BOM
Audio (X09-1240-10 B/2) (Power Supply Section)
Cm49,50:10,000uF/50V (ale-pol) 35x80mm 2-pin tab
667-ECE-T1JA183EA (Snap In 18000UF 63V ELECT THA) $10.79
Cm52:22u/50V (ale-pol) use 47uF/63-100V
667-EEU-FR1J470 (Aluminum Electrolytic Capacitors - Leaded 63volt 47uF 6.3X11mm LS:2.5mm Bulk Strait) $0.389
667-EEU-FR1J470B
647-UPS1J470MPD1TA (47uF 63V 20% 105c) $0.244 D:8mm L:11.5mm LS:3.5mm Product: Low Impedance Electrolytic Capacitors
Cm53:100u/50V (ale-pol) use 220-470uF/63-100V
667-EEU-FR1J221L (Aluminum Electrolytic Capacitors - Leaded 63volt 220uF 10X25mm LS:5mm Bulk Strait)
667-EEU-FR1J221LB
Cm55:220uF/16V (ale-pol) use 220-470uF/25V
667-EEU-FR1E331 (Aluminum Electrolytic Capacitors - Leaded 25VDC 330uF 8x11mm LS3.5mm )
Cm56:100uF/16V (ale-pol) use 470u/25V
667-EEU-FR1E471YB (Aluminum Electrolytic Capacitors - Leaded 25VDC 470uF 8x15mm LS 5.0mm)
Cm57,58:220uF/35V (ale-pol) use 470uF/35V
667-EEU-FR1V471 (Aluminum Electrolytic Capacitors - Leaded 35VDC 470uF 10x16mm LS5mm)
Qm25:2SC789(Toshiba,70V,4A,30W@25Ccase,hfe=40-240@0.5A,Ft=3MHzmin,TO-220AB,BCE)
512-KSD363YTU (BCE) $0.967
Audio (X09-1240-10 A/2) (PREDRIVER)
Cm1,2:2.2uF/25V (tant-pol) I/P coupling D5mm,LS4mm
667-ECQ-V1H225JL (Film Capacitors 2.2uF 50V 5%) $1.21
555-RFS50V2R2ME3#5 (2.2uF 50V 20% Audio SILMIC II Case Diameter:5 mm Case Length:11 mm Lead Spacing:2 mm $0.333
647-UKL1H2R2MDDANA (50 Volt 2.2uF 20%) $0.178
Cm3,4:0.22uF/35V (tant-pol) Sub-filter D5mm,LS4mm
667-ECQ-V1H224JL (Film Capacitors .22uF 50V 5%) $0.322
647-UKL1HR22KDDANA (50 Volt 0.22uF 105C 5x11 2LS) $0.344
Cm7,8:47uF/16V (ale-np) d10mm,LS4mm
647-UES1E470MPM (Aluminum Electrolytic Capacitors - Leaded 25volts 47uF 85c 10x12.5 5LS) $0.655
Cm11,12:1UF/50V (ale-pol,orange ELNA,D:5x12mm) (tone)
667-ECQ-V1H105JL (Film Capacitors 1uF 50V 5%) $0.755
555-RFS50V010ME3#5 (Aluminum Electrolytic Capacitors - Leaded 1uF 50V 20% Audio SILMIC II ) $0.333
Cm17,18:10UF/25V (ale-pol)
555-RFS25V100ME3#5 (10uF 25V 20% Audio SILMIC II) $0.333
Cm19,20:100uF/10V (ale-pol)
667-EEU-FC1J101
Cm21,22:10uF/25V (ale-pol,D:5mm,LS:4mm)
647-UKL1E100MDDANA (1uF 50 Volt 105C 10% 2mm LS Case Diameter:5 mm Case Length: 11 mm Lead Spacing: 2 mm) $0.344
647-UPW1E100MDD
Cm24:330uF/50V (ale-pol,16(D)x35mmx7.5mmLS) (-47V filter,use 560uF/63V)
667-EEU-FR1J561L
Cm27,28:1uF/50V (ale-pol) D:5
667-EEU-FC1H1R0
555-RFS50V010ME3#5
Cm33:47UF/10V (ale-np) 10(D)x12(H)x4mmLS
Cm34:100uF/25V (ale-pol,D:12x22x5mmLS)
667-EEU-FC1J101
Q1,3:2SC2261(O)(y) (Sanken,80W,TO-3)
Q2,3:2SA981(O)(Y) (Sanken,80W,TO-3)
TO-3 micas (Need a total of 4): 534-4636, 534-4667
Qm1~4:2SA750(1)(E) (TO-92,ecb)
512-KSA992FTA (Vce=120V,Ic=50mA,Pd=500mW,Ft=100M,hfe=300-600,TO-92,ecb)
2SA1083,2SA1034(D)(E)
Qm5~8:2SC1775A(E)(F) (Vce=120V,Ic=50mA,Pd=300mW,Ft=120M,hfe=400-1200,TO-92,ECB)
512-KSC1845FTA (Vce=120V,Ic=50mA,Pd=500mW,hfe=400-1200,Ft=110M,TO-92,ECB)
512-KSC2316YTA (Vce=120V,Ic=800mA,Pd=900mW,hfe=120-240,Ft=120M,TO-92L)
Qm9,10:2SA872A(E)(F) (Vce=120V,Ic=50mA,Pd=300mW,Ft=120M,hfe=400-1200,TO-92,ECB)
512-KSA916YTA (Vce=120,Ic=800mA,Pd=900mW,Ft=120M,hfe=120-240,TO-92L)
Qm11,12:2SD600K(E)(F)/2SC1567A(Q)(R) (TO-126,ECB)
512-KSC2690AYS (NPN,Ic=1.2A,Vce=160V,Pd=1.5W,Ft=155M,hfe=160-320,TO-126ML,ECB)
863-2SC3902S (NPN,Ic=1.5A,Vce=160V,Pd=1.5W,Ft=120M,hfe=140-280,TO-126ML,ECB)
Qm13,14:2SB631J(e)(F)/2SA794(Q)(R) (TO-126,ECB)
512-KSA1220AYS (PNP,Ic=1.2A,Vce=160V,Pd=1.5W,Ft=155M,hfe=160-320,TO-126ML,ECB)
863-2SA1507S (PNP,Ic=1.5A,Vce=160V,Pd=1.5W,Ft=120M,hfe=140-280,TO-126ML,ECB)
Qm19,20:2SC1890A(E)(F) (Vce=120V,Ic=50mA,Pd=250mW,hfe=400-1200,Ft=200M,TO-92,ECB)
Qm21:2SC945(Q)(R) (Vce=50V,Ic=150mA,Pd=250mW,hfe=400-270,Ft=250M,TO-92,ECB)
512-KSC945CYTA (Vce=50V,Ic=150mA,Pd=250mW,hfe=400-270,Ft=300M,TO-92,ECB)
512-KSD1616AGBU
Qm22,24:2SA733(Q)(R) (Vce=50V,Ic=50mA,Pd=300mW,hfe=250-1200,Ft=180M,TO-92,ECB)
512-KSA733CYTA (Vce=50V,Ic=150mA,Pd=250mW,hfe=120-240,Ft=180M,TO-92,ECB)
Qm23:2SC1735(E) (Vce=100V,Ic=500mA,Pd=800mW,Ft=120M,hfe=150-300,TO-92-L,BCE)
512-KSC2316YTA (Vce=120V,Ic=800mA,Pd=900mW,Ft=120M,hfe=120-240,TO-92L,ECB)
512-KSC1009YTA (Vce=160V,Ic=700mA,Pd=800mW,Ft=120M,hfe=120-240,TO-92L,ECB)
Dm1,2,5,6,9,10:1S2076,1S1555 (100mA,35V,DO-35)
512-1N4148TA
Dm3,4:STV-4HG
Dm8,16,17:WO6B (DO-41,Glass)
512-1N4004
Dm11:1S2076A (35V,150mA,250mW,trr=8ns,C=3pF,DO-35)
512-1N4148TA
Dm15:M4C-3 (200V/10A bridge? with heatsink)
512-GBPC2506W Bridge Rectifiers 25A Bridge Rectifier 25x25mm $3.41
567-624-60AB (21x21x15mm) $1.53
Dm18:YZ-140 (14V zener glass 500mW)
512-1N5244B
Dm19,20: WZ-240 (24V zener glass,DO-41)
512-1N4749ATR
512-1N5252B Fairchild 24 V, 0.5W Zener
Vrm1,2:500ohm pot
652-3309P-1-501 $0.60
Tuner(X05-1480-10, -61, -81 A/4)
Cg22,51:0.47u/50V(ale-pol,dc filter)
647-UPW1HR47MDD
647-UKT1HR22MDD (50volts 0.22uF 20%) $0.156
Cg25,39,53:1u/50V(ale-pol,dc filter)
647-UPW1H010MDD
Cg34,38,47,48,73,78:10u/25V
647-UPW1E100MDD
Cg49:220u/16V(ale-pol,dc filter)
647-UHD1C331MPD
Cg52:0.22u/50V(ale-pol,dc filter)
647-UKT1HR22MDD
Cg69,50:47u/10V(ale-pol,ac coupling)
555-RFS10V470ME3#5
Cg73,74,75,76:10u/25V(ale-pol,ac coupling)
Cg77:33u/16V(ale-pol,dc filter)
647-URZ1C330MDD
Cg79:47u/16V(ale-pol,dc filter)
647-UPW1E470MDD
Cg80:33u/16V(ale-pol,dc filter)
647-UPW1C330MDD6
Cg81,103,104:100u/25V(ale-pol,dc filter)
647-UPW1E101MED
Cg82:100u/10V(ale-pol,dc filter)
647-UPW1A101MDD
Cg85,86:3.3uF/10V(tant-pol,sig coupling for phono i/p)
Cg87,88:47uF/50V(ale-pol,sig coupling,sig coupling for phono feedback)
555-RFS35V470MH3#5 (Aluminum Electrolytic Capacitors - Leaded 47uF 35V 20% Audio SILMIC II)
Cg97,98:4.7uF/50V(ale-pol,sig coupling,sig coupling for phono o/p)
667-ECQ-U2A103ML (Use across the AC switch terminals)
667-ECQ-U3A103MG
576-V20E140P Varistors 140Vrms 10kA 1900pF 20mm Disc
