This is some of the info that got me thinking about this subject. Some scientific reasoning. Any more thoughts??
"The truth is that biamping makes sense in certain cases, even with a passive crossover, but biwiring is pure voodoo. If you move one pair of speaker wires to the same terminals where the other pair is connected, absolutely nothing changes electrically. The law of physics that says so is called the superposition principle. In terms of electronics, the superposition theorem states that any number of volt- ages applied simultaneously to a linear network will result in a current which is the exact sum of the currents that would result if the voltages were applied indi- vidually. The audio salesman or 'phile who can prove the contrary will be an instant candidate for some truly major scientific prizes and academic honors."
First; it states at the beginning this is only a theory. Second; by definition, linear means in a straight line. What does this have to do with bi-wiring?
a (1) : of, relating to, resembling, or having a graph that is a line and especially a straight line : straight (2) : involving a single dimension
b (1) : of the first degree with respect to one or more variables (2) : of, relating to, based on, or being linear equations, linear differential equations, linear functions, linear transformations, or linear algebra
c (1) : characterized by an emphasis on line <linear art> (2) : composed of simply drawn lines with little attempt at pictorial representation <linear script>
d : consisting of a straight chain of atoms
2
: elongated with nearly parallel sides <linear leaf> — see leaf illustration
3
: having or being a response or output that is directly proportional to the input
4
: of, relating to, or based or depending on sequential development <linear thinking> <a linear narrative>
