Sta-2250
when you get to adjusting the idle current you will see why i chose to replace those VR's with mutli turn equivs(adj is so sensitive)as access is a bit tight i also chose to mount them on a small matrix board mounted close by, that also had the resistor test points run to it , not everyones approach but it works for me,
