Yes, I am not afraid to use the A-word!!
Anyway, my home theater room room has evolved a lot over a 6 year period. I started with a Philips CRT HDTV and some old 4320 JBLs.
They evolved through a couple upgrades and moved upstairs when I got some JBL 4341 Studio Monitors and put them upfront as mains.
I got a pair of JBL L20T speakers and ceiling mounted them as rear surrounds tried a cheap Sony (BestBuy) sub, but replaced it when I found a JBL B380 15" passive sub.
For electronics I started with a a low power HK AVR, went through a few of those and wound up with the (then) top of the line Hk AVR7300 - which turned out to be an unstable Piece Of Junk. I tried biamping the 4341 monitors with various JBL/UREI active crossovers and settled on an Ashly piece.
For amps, again, once I went to biamp I pulled front mains off the HK receiver and used JBL/UREI 6230 and 6260 pro amps. Tried some other stuff, and wound up with a pair of Adcom GFA-555s (not IIs). I'd found an HK Citation 22 that I bridge to run the sub with ... something like 600w.
I later added a pair of JBL L100T (with T3 crossovers) for side surrounds,
and got a modern JBL LC2 for center channel ... Got an Adcom 2535 3/4 channel amp for the center & rear channels, and an Adcom 545 for the sides
When the AVR73200 blew I got a Yamaha AVR for a standby, then bought a used Integra PreProcessor ... and an Oppo BDP-93 finished the system.
Yep, it was an Altar of Audiophilia - overkill for the small room.
Since December I decided to uncomplicate all of this stuff - sold off the B-380 sub but replaced it with a JBL 4641 Pro sub!
I kept reading about Time Frame speakers here so I found and bought an inexpensive pair of DCM TimeFrame speakers (TF500s) and loved the sound and the thin box dimensions. Collected more, TF600, then TF400, found some TF700s, and then a pair of TF1000s ... even got a pair of TimePiece "satellite" speakers - so I could use one of them as a center ...
Then i got serious ... Sold off the L100Ts, and the 4341 monitors. Tore down the biamp rack and found a Salamander Audio cabinet at a yard sale for under $200 ... Sold off the Scan Teak rack I'd had for nearly 30 years, and thinned the amps and gear.
Wound up setting the room up as a DCM TimeFrame HT system ... TF1000s as front mains on one Adcom 555,
TF600s as side surrounds, and the TF400s as rear surround. Moved the JBL L20Ts up to my office (nice!)
Put a TimePiece in the center and the tonality was nice and it could play loud enough for us ... great!
