It is more likely that the alignment of the tuner front end has been affected by the cleaning process than any electronic components being altered.
If a non-residual cleaner was used, it must still be fully dried before normal operation can be expected. If any cleaner, residue, or contaminants ended up in or on the trimmer capacitors on top of the tuner VC assembly, that can affect alignment.
If any type of cleaner which deposits residue (such as lubricant or protectant) was used, a non-residual cleaner should be used to remove all of that. Of course, the second cleaning must be allowed to dry fully. That can take up to a day in the right conditions.
If the tuner VC and surrounding circuitry is properly cleaned and dried, and if the problem still exists, post your results and detail so further instruction can be given.
