bhuskins
Ok so I'm starting my own thread that continues the discussion started on the recap thread for this same amp...
Here's where I'm at:
Picked up an M-70 that was in protection mode continually.
I recapped the power board (it had visibly leaking caps), C701 to C706 and the infamous .22mf 250v x2 cap (C607) on the control board. I also dismantled the relays and cleaned them.
It powered up and came out of protection which is good, but I'm not getting any sound (that I'm supposed to get)
Initially, it was making a high pitched hiss/squeal that went away after checking everything but I think it may have been a result of warming up. Because this morning when I started it up cold it had the same high pitched squeal. After 15 minutes of warming up with no signal applied and not touching a thing it slowly went away and is now non-existent. As the sound dissipated so did the meters from about 5 bars down to no bars. Might be from the relays because if I jack with them i can get remnants of the whine to come back. Not sure what's going on there but no sound coming from the source regardless.
Anybody know of a matching replacement to the DEC type MSJU 12vdc #531 speaker relays?
What's up with those magnets taped to the case on the side of the relays?
Here's what I've tested...
-B power supply voltage is at 69.1v
Photo coupler voltage is at 1.26v
DC offset at the speaker terminal with the relay off is -.7v left and 0.0v right
Any suggestions on how to proceed?
