but I really don't know! Electronics in general is not my strong suit and I'm not sure what the right answer is here.
I'm trying to migrate a friend from a TV/HTIB setup to a proper receiver, speakers, etc. keeping only the original TV which is a halfway decent but older Sony 40" LCD.
My question is this. I spend a lot of time there and I'm kind of a radio junkie, I listen to the radio as much as I watch TV, so I definitely plan on hooking up an antenna to the receiver when I get this all together.
My addled brain seems to recall that the FM band is actually in the middle of the VHF band, so a TV antenna should work for FM as well yes?
I was thinking of providing her something along the lines of a Terk Silver Sensor and then using a splitter to feed both the TV and the receiver. (she currently only uses cable) that way she could watch OTA television if desired as well as have radio reception.
Is there anything wrong with this plan? Can I use just a cheap passive splitter, or should I use one with filters to filter out the UHF frequencies etc. for the connection to the receiver? And if the latter, could you recommend a product?
Or should I ditch the idea completely, and just use a dipole for FM and worry about the TV separately?
thanks much!
thanks much!
