Hello Gang!
I have picked up a non-working CDX-1100. It powers up but it does not read CD's. After some reading, it appears that the platter motor would be the main culprit or (and hopefully not) the laser.
I say the platter motor is the main suspect, because at first, the was spinning slowly and then it would stop and nothing would happen after. Once I lightly touched the sniping CD, then it never span again. So it could be a contact but most likely the motor (based on what I red).
Anyone's 2c is welcomed.
As of now, my question is, which other Yamaha players use this motor (I am thinking of a donor) or, can it be replaced with other manufacturer part?
What is the rated voltage..I should have checked that before I took it apart:scratch2:
Please help!
Please help!
