I have 4 woofers from the original Infinity RS II's...they all test good, but need new foam.
I've never re-foamed woofers. Are these a bad place to learn? I'm pretty DIY capable when it comes to electronics, just never got around to any woofers.
They seem pretty simple as far as the stamped frame is concerned, where you'd glue the foam on the lip. Using shims doesn't look possible, so I assume using a 30Hz tone would be the other option to keep the voice coil centered.
Anything special about the way these need to be re-foamed? Any particular foam to use? What glue for the clear cones? Any tips would be appreciated.
